separate power for arduino?
Discussion in 'UDOO BOLT' started by hindumagic, Mar 3, 2021.
  1. hindumagic
    hindumagic New Member
    Mar 3, 2021
    Hi all,
    I'm thinking of getting one of these cool boards, but I have a question I haven't found an answer to yet.
    Can the onboard arduino be powered while the Ryzen side of things is off/suspended? It would be fun to use the arduino side to power up the full system, or run lights while the main system is powered down.
    Anyone try this or know if it is doable? The docs for the Leonardo pinout label all power as OUT (clearly not in), so I assume that you can't power it through that interface.
    Thanks!
  2. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    BOLT's built-in Arduino Leonardo is using BOLT's internal 5V power source thus cannot be
    separately powered (unless you doing the tiny 0403 SMD work and modifying the PCB <-- don't do it.)
    evaloverde likes this.
  3. hindumagic
    Mar 3, 2021
    Ok, thanks for the info. Quite disappointing news, to be honest. It would have been great to supply an external 5V to just it, or have an independent power path through the mainboard. A missed opportunity to have a low power device monitor things and then wake up the Ryzen to take care of business.
  4. waltervl
  5. hindumagic
    Mar 3, 2021
    Thanks waltervl, I'll look into it. Thinking that an itx based board will work, depending on the power draw. cheers.
  6. evaloverde
    Apr 29, 2019
    236
    60
    Thanks for helping Hindu guys
  7. Crocodoris
    Crocodoris New Member
    Jul 31, 2021
