Use PWM Pins from M4 // Duty and Period
Discussion in 'UDOO NEO' started by TomFreudenberg, Dec 26, 2022.
  1. TomFreudenberg
    TomFreudenberg Member
    May 12, 2014
    59
  2. TomFreudenberg
    May 12, 2014
    59
    First of all - "Happy new Year" :)
    Things I found so far is from Servo library
    if (!PwmIsEnabled(pwmChn)) {
    // PWM Startup code
    _bsp_pwm_io_init(pwmChn, 0xff);
    pwm_disable(pwmChn);
    pwm_set_clock(pwmChn, kPwmClockSourceIpg);
    pwm_set_fwm(pwmChn, DEF_SERVO_FWM);
    pwm_set_prescaler(pwmChn, DEF_SERVO_PRESCALER);
    pwm_set_poutc(pwmChn, DEF_SERVO_ACT_POL);
    pwm_set_period(pwmChn, DEF_SERVO_TICKS_PERIOD);
    pwm_set_resolution(pwmChn, DEF_SERVO_TICKS_PERIOD);
    pwm_set_repeat(pwmChn, DEF_SERVO_REPEAT);
    pwm_enable(pwmChn);
    pwm_set_sample(pwmChn, defPulseWidth);
    But without any additional documentation I can't make it for our intention.
    We have to change the PERIOD and not the PULSE.
    We need to change the period from 8 Hz up to 4.500 Hz with a dutycyle of 50% based on the set period.
    Please may someone step in and provide us with the right information to solve this issue shortly.
    Thanks in advance
    Tom
  3. TomFreudenberg
    May 12, 2014
    59
    @moderator - why are my posting on hold everytime?
    > This message is awaiting moderator approval, and is invisible to normal visitors.
