Hi, I try touch screen 15" panel with Linaro Ubuntu 12.04 LTS and it work... However, I try to use it on Android (it seems easier...), display is OK but... When I touch the screen, nothing happened and I don't have idea to fix it. So, please... I need help. Thanks. Regards.
It's a known issue. Everything will be solved with the next Android Image (we'll release it next week).
Ok, Thank you delba, it's a good news. I tryed several things but nothing... So good luck guys! See you soon.
Hi, could you give me any info when touchpanel will work with android (quad + 15")? or any patch for current release ? thanks! Bart
For information, we can read on the ticket : "Unfortunately the touch feature is still an issue in both 7″ and 15″ LVDS using the UDOO Dual. We’re working very hard to solve this problem that will be fixed in the next release (1.5)." So, we'll wait the next upgrade... Thanks for your work delba.
Hello, if you give me sources and instruction I can try to make own kernel compilation. Like another users, I have same trouble with 15" quad, touch panel still don't work. If Udoo dual works fine, I can order other board... thanks for any info, Bart
Hello! perhaps somebody have previous version (1.0-1.2) of android, which worked with 15" touch ? thx Bart
Hi, 15in touchpanel still don't works ... please help and share worked android (any version). thanks!
Hello All, Just bumping this thread. Wondering when Android 1.5 with verified touch support for 15 inch is expected to be released? I received reply from support yesterday (March 17) that fix will be in the next release. I am running on Quad. Thanks ...
