Hi all, I am a JavaScripter that works with Node.js and Johnny-Five library to create servers to control hardware remotely, and when I installed Node.js in my Udoo Quad with Ubuntu 12.04 LTS, I did not be able to make it work. When I try to use the node console, it freezes and the same happens with npm. I have installed everything as usual, and I even reinstalled the operative system, but it does not work. The weird thing is that I have tried the same in the beta of Debian, and all worked like a charm. Do you know any solutions to fix Node.js in Linaro Ubuntu 12.04 LTS? Installation process: Code: wget http://nodejs.org/dist/v0.10.25/node-v0.10.25.tar.gz tar -zxvf node-v0.10.25.tar.gz cd node-v0.10.25 ./configure --without-snapshot make sudo make install cd .. rm node-v0.10.25.tar.gz rm -r node-v0.10.25
Maybe this thread will help you: Getting latest node.js to run on UDOO Have you tried an earlier version of node.js ?
I have tried what is in that thread only with Node.js 0.10.25, but still not working. I will try to obtain an older version, but I'm not sure if it will work. I think the problem could be in missing libraries, but I can't find which one are missing. Libraries that are installed in Debian but not in Ubuntu.
Did you manage to get node.js going? I did, what you want is pilwon's nodejs-for-linaro-ubuntu-master.zip available on github. No compile required, unzip it to get the binaries and you should be in business.
Hopefully this message is still interesting for you: It is a problem based on the standard gcc 4.x which is installed on the lubuntu image by default. Please check out my guide to get an up-to-date nodejs running on your systems: http://meteor-universal.tumblr.com/post ... untu-12-04 Tom
