Ciao, http://sourceforge.net/projects/udoorep ... rce=navbar http://sourceforge.net/projects/udooreprap/files/ Download (Files) -> un "ZIP" -> Win32DiskImage (32GB SD-Cart) write -> SD-Card plug in UDOO Quad slot and Power on. If you are in the same LAN, open Browser http://udoo-reprap and the registration of OpenMediaVault must have on the screen. Openmediavault http://udoo-reprap user= admin password = reprap OctoPrint http://udoo-reprap:5000 user = udoo password = reprap Webmin https://udoo-reprap:10000 user = root password = reprap VNC-Viewer-5.1.0-Windows-64bit vpn user = reprap putty udoo-reprap Port:22 user = root password = reprap To install the Services is your Job CAUTION: No support of LCD + touch, no HDMI, no webcam support and SATA could run, but not tested. Cura and Slic3r only on commandline - OpenGL GLX is not because the GPU driver module-core does not yet work on armhf. http://forums.reprap.org/read.php?336,340416
Great work udoo-reprap! Could you add a little introduction to you work? I guess there are many UDOO users that could be interested but with little knowledge on the topic. Thanks!
This is a beta. The Hardware not work with debian armHF (GPU, HDMI, WEBCAM ...) I will try to configure this solution with Linaro Ubuntu 12.04 LTS If the OpenGl is working, and i can Plug the 7" Touch-Display and the Webcam ant a Sata SSD, than I make the Documentation. I concentrate now to make a stable rel. If you have specific Questions, please write me an E-Mail angelo@abcona.de
