Dear all, Can I change the resolution for my HDMI monitor with android 4.3.. should I compile kernel or source..? I have no LCD... for example, I want to change my monitor to 1440x900... if anyone aleady have the solution, give me some about it... please... Sorry for my poor English.. Thanks...
I followed the link and in terminal I sent this command: Code: root@udoo:/# setenv bootargs console=ttymxc1,115200 init=/init video=mxcfb0:dev=hdmi,1280x1024M@60,if=RGB24,bpp=32 video=mxcfb1:off video=mxcfb2:off fbmem=28M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale mem=1024M As result I got: Code: root@udoo:/# The I've tried to send the save environment command as proposed: Code: root@udoo:/# saveenv But gived this error: Code: /system/bin/sh: saveenv: not found 127| Rebooting will not help, I got the same screen resolution as before. Would you tell me exactly where I'm wrong?
MX6DL UDOO U-Boot > saveenv Saving Environment to MMC... Writing to MMC(2)... done You should execute command "saveenv" on [u-boot consol] like this... For access to [u-boot consol], you can see the file "http://udoo.org/download/files/Documents/UDOO_Starting_Manual_beta0.4_11_28_2013.pdf" page 18... Gook luck..
i've tried those commands.. # setenv bootargs console=ttymxc1,115200 init=/init video=mxcfb0:dev=hdmi,1440x900M@60,if=RGB24,bpp=32 ... # saveenv # boot everything was ok.. But after boot, it was displayed only 600x480 resolution... and then i have do several test... like this.. < Udoo Android Version> <Monitor that we have> <Result> 1. udoo_dual_android_2.0/2.0.1 1400x900 X 2. udoo_dual_android_2.0/2.0.1 1280x1024 X 3. udoo_dual_android_2.0/2.0.1 1920x1080 O 4. udoo_dual_android_1.4.1 1400x900 O and then i had another test to change the resolution on the android consol with udoo_dual_android_2.0/2.0.1 # wm size 1440x900 # wm density XXX i could change the size(1440x900), but i can't get the exactly density for my monitor.... Does anybody know about this result? help me.. plz....
i have found another issue.... http://www.element14.com/community/thre ... ed-android By using HDMI <-> DVI convert will not work.... But i don't know why the previous UDOO_Android version did work for my same monitor(1440x900).. I think there is a little difference in kernel between 4.3 and 4.2....
