Hello. We just installed fresh LUbuntu 12.04 armhf on UDOO. Everything works fine, except glxgears. It displays empty black window. When we use VIV_DESKTOP=0 glxgears than it works, but FPS is about 80. What can we do to get full GL with max speed? Is there any way to get official drivers and compile it manually?
Hi there -- I don't have an answer for you but can confirm this behavior on UdooBuntu. I was unable to get any EGL / GLES tests to render and was only able to get the GL tests to render when setting VIV_DESKTOP environmental variable to 0. (i.e. export VIV_DESKTOP=0) I attempted to follow these instructions: http://www.udoo.org/ProjectsAndTutorial ... lioID=1394 post5887.html?hilit=egl#p5887 http://repository.timesys.com/buildsour ... 0.9-1.0.0/ http://www.udoo.org/ProjectsAndTutorial ... lioID=1394 Etc, but the required libEGL-fb.so / libEGL-x11.so, etc are not to be found on UdooBuntu. Is there a trick for getting this installed so we can get support for GLES / EGL contexts? My current working solution is to use the JAS Jessie build, but would prefer to use / support the "official" build. Thanks, Christopher
