Does udoo_quad_revC_yocto_09072013.img work ?
Discussion in 'Other OS' started by peter247, Jun 21, 2014.
  1. peter247
    peter247 Member
    Mar 10, 2014
    263
    I`ve downloaded it and unzipped the image without fault , but tried to write in to 2 sd card with the same result.
    U-Boot 2009.08-secoimx6dq_m975_1GB_LV_2013061540 (Jun 21 2013 - 15:38:38)
    CPU:   Freescale i.MX 6 family 0.0V at 792 MHz
    Temperature:   26 C, calibration data 0x5844f769
    mx6q pll1: 792MHz
    mx6q pll2: 528MHz
    mx6q pll3: 480MHz
    mx6q pll8: 50MHz
    ipg clock     : 66000000Hz
    ipg per clock : 66000000Hz
    uart clock    : 80000000Hz
    cspi clock    : 60000000Hz
    ahb clock     : 132000000Hz
    axi clock     : 264000000Hz
    emi_slow clock: 29333333Hz
    ddr clock     : 528000000Hz
    usdhc1 clock  : 200000000Hz
    usdhc2 clock  : 200000000Hz
    usdhc3 clock  : 200000000Hz
    usdhc4 clock  : 200000000Hz
    nfc clock     : 24000000Hz
    Board: MX6Q-SECO_Q7:[ POR ]
    Boot Device: NOR
    I2C:   ready
    DRAM:   1 GB
    MMC:   FSL_USDHC: 0,FSL_ESDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
    In:    serial
    Out:   serial
    Err:   serial
    Net:   got MAC address from IIM: 00:c0:08:88:a2:bc
    FEC0 [PRIME]
    Hit any key to stop autoboot:  3
    It keeps looping .. and there is no 3-2-1
  2. peter247
    peter247 Member
    Mar 10, 2014
    263
    wow , no one as every tried the yocto image !!!!!!!
  3. delba
    Yocto has some issues we still trying to solve but since we're focusing on different distros this fix could take a while :(
