How to change resolution?
Discussion in 'Android' started by lostfly, Jan 27, 2014.
  1. lostfly
    lostfly New Member
    Dec 27, 2013
    Android is not see at full screen in my tv.
    Thanks.
  2. matteodifede
    matteodifede New Member
    Jul 1, 2014
  3. YannXplorer
    YannXplorer New Member
    Feb 12, 2014
    18
    You can set resolution and density with the following command :
    wm size 1024x768 for example.
    To do this, you have to connect your board on USB serial to a PC and launch Putty to connect them. Link the board to a hdmi screen to see modification.
    Let boot the board and on the Putty screen, enter the command below with yoour resolution.
    Enjoy!
  4. unic8
    unic8 New Member
    Oct 31, 2013
    @YannXplorer
    could you please add some details on this process?
    1. i connect the micro usb serial port of the udoo to the pc
    2. i launched putty and choose "Serial" connection and entered the COM port of the udoo with baudrate 9600
    a little bit more information would help. could this process also be done via emulated terminal on the latest Android image (since this had root access via supersu)?
    thanks!
