Update: Finally have Touch and TFT updates working. In video M4 is initialising and controlling the display and a simple UI is presented allowing toggling a green LED. Blog link if of interest and again this is custom code (FreeRTOS). Finally got this extremely cheap 2.0" Touch TFT display to output some data using the M4. As normal I'm not using the Arduino libraries but custom code (FreeRTOS). Next challenge is to see if touch can be made to work.
Interfacing that type of screen to A9 is convoluted because there no parallel screen interface exposed. NEO only has hdmi or lvds on A9 and thus require external signal conversion back to RGB parallel. Unfortunately the native LCD parallel interface on the A9 is used to provide the HDMI signal.
Unfortunately I don't use eclipse as I have access to a commercial ARM DS5 environment for the occasions where I need jtag debugging (which is rare).
