Add kernel module at boot
Discussion in 'UDOO DUAL' started by Justyn Bell, Nov 15, 2016.
  1. Justyn Bell
    Justyn Bell New Member
    Nov 15, 2016
    I need g_ether to be loaded at boot in order to ssh to the device via USB, however, when I add g_ether to /etc/modules, it isn't loaded at boot.
    How do I load kernel modules at boot on the Udoo?
    UDOObuntu 2.1
    Justyn
  3. Justyn Bell
    Nov 15, 2016
  4. waltervl
    I just adviced what is in the documentation. Perhaps you missed this, I saw no reference that you already tried it. If it is not implemented the Udoo team should remove this page for the Udoo Dual.
    I know from the Neo topics that especially on Macs it can be troublesome to use the USB-direct, see also the troubleshoot section on that manual page.
    For your original question about adding kernels modules I have no idea.. I suppose you already took a look at this: http://www.udoo.org/docs/Advanced_Topics/Compile_Linux_Kernel.html
  5. Justyn Bell
    Nov 15, 2016
    Rebuilding the entire kernel with g_ether built in instead of a module isn't really a satisfactory answer.
    Loading modules at boot is a simple task in other Linux platforms, there's probably something I'm missing that a Udoo developer can clue me in on.
  6. Justyn Bell
    Nov 15, 2016
    I just added `modprobe g_ether` to /etc/rc.local and called it a day.
