Hi. I'm trying to use Android 4.4.2 (kitkat) on my Udoo dual basic. Android start, i see the desktop and after 10-20sec the card restart. I don't have this problem with ubuntu (works perfectly)... I really need android to work with Gapp. Any idea to solve my problem ? Power supply : 12V 2A (trying 4 different) Here the com3 : binder: 22393: binder_alloc_buf failed to map pages in userspace, no vma binder: 31756:31756 transaction failed 29201, size 4340-4 request_suspend_state: wakeup (0->0) at 220120717696 (1970-01-02 00:04:50.389350027 UTC) init: untracked pid 31756 exited init: untracked pid 22648 exited alarm_release: clear alarm, pending 0 init: untracked pid 22513 exited init: untracked pid 22542 exited init: untracked pid 22568 exited init: untracked pid 22622 exited init: untracked pid 31780 exited init: untracked pid 22582 exited binder: release 31780:31780 transaction 170125 out, still active binder: release 22113:22113 transaction 170115 out, still active binder: release 22113:22113 transaction 170068 in, still active binder: release 22513:22524 transaction 170114 out, still active binder: release 22513:22524 transaction 170099 in, still active binder: release 22393:31771 transaction 170068 out, still active binder: send failed reply for transaction 170115, target dead binder: send failed reply for transaction 170068, target dead binder: release 22393:31778 transaction 170114 in, still active binder: release 22393:31778 transaction 170099 out, still active binder: send failed reply for transaction 170114, target dead binder: send failed reply for transaction 170099, target dead binder: send failed reply for transaction 170125, target dead ERROR: v4l2 capture: slave not found! ERROR: v4l2 capture: slave not found! request_suspend_state: wakeup (0->0) at 226659136695 (1970-01-02 00:04:56.927769360 UTC) eth0: no PHY, assuming direct connection to switch PHY 0:00 not found eth0: could not attach to PHY acc_open acc_release binder: 32083:32083 transaction failed 29189, size 100-0 init: sys_prop: permission denied uid:1003 name:service.bootanim.exit binder: release proc 32083, transaction 225824, not freed binder: 9060:9060 transaction failed 29189, size 4340-4 alarm_release: clear alarm, pending 0 request_suspend_state: wakeup (0->0) at 289530734037 (1970-01-02 00:05:59.799365702 UTC) init: untracked pid 32203 exited init: untracked pid 32261 exited init: untracked pid 32236 exited ERROR: v4l2 capture: slave not found! ERROR: v4l2 capture: slave not found! init: untracked pid 32313 exited init: untracked pid 32282 exited init: untracked pid 32341 exited request_suspend_state: wakeup (0->0) at 295865097371 (1970-01-02 00:06:06.133729702 UTC) eth0: no PHY, assuming direct connection to switch PHY 0:00 not found eth0: could not attach to PHY acc_open acc_release binder: 9370:9370 transaction failed 29189, size 100-0 init: sys_prop: permission denied uid:1003 name:service.bootanim.exit Thanks !! edit : I've seen that it can be a bug who affects the real-time clock's quartz. The problem can be easly solved by cutting one of the component's pin. But in the video it's a quad and not a dual, can i cut any pin of the same component ? Or it's specific ?
Hi there sebastien 28, as I've already answered via email, it's not specific and you can do it by following the instruction on this video Cheers
Didn't change nothing my android continue to reboot every time, is end a request to the support but no answer (06/18).
Hi there sebastien28, my colleagues are fixing your issue this very moment. Please be patient, you'll get an answer in the ticket in short time.
So support accept the RMA(substitution) of the board, i have two udoo dual with the same problem (serial number are K15073174 and K15073172), there is a problem on this series ? Or juste am i unlucky ?
Actually no, there's no specific problem for UDOO Dual, but I'd like to highlight that if there is the doubt of hardware problem the right process is to open a ticket.
