I'm looking for a way to convert the M.2 B slot to a USB controller so I can pass it through to a virtual machine (I need the existing USB 3.0 controller for the host OS). In the Udoo X86 docs, I noticed the M.2 E slot has USB 2.0, but I'm already using that slot for a WiFi card. Does anyone have any ideas? Thanks.
UDOO x86's key-B slot does not have a direct-USB connection arrangement. You'll have to purchase a PCIe to USB 3.0 adapter such as this https://www.ebay.com/itm/M-2-NGFF-N...rt-USB3-0-Expansion-Card-Adapter/132797183001 (Amazon and Newegg also have it.) P.S. it's using Renesas/NEC uPD720202 controller (pls check if VMware supports it) PPS, there is a version that has two USB 2.0 out, that adapter won't work since it's just a USB 2.0 hub using M.2's USB leads as its feeder (note that UDOO x86 does not have USB 2 connection)
