Arduino 101 hangs when using serial
Discussion in 'UDOO X86' started by hseldon, Nov 26, 2017.
  1. hseldon
    hseldon New Member
    Apr 18, 2017
    15
    Hi guys,
    my Arduino 101 has always worked as expected but since about a month I'm experiencing a weird issue. The sketches run fine, but every time I try to connect via serial to the Arduino it hangs.
    Uploading new sketches via DFU works flawlessly.
    Does it happen to anyone else? Any ideas?
    Thanks
  2. avignani
    avignani New Member
    Jun 16, 2017
    I have the same problems in Windows 7, see my previous post. The serial port works fine under linux.
    Are you using Windows 10?
  3. hseldon
    hseldon New Member
    Apr 18, 2017
    15
    No, I'm using Linux.
    I believe the problem you described is unrelated: you have issues with the COM drivers, not with the Arduino itself
