Arduino IDE erros
Discussion in 'UDOO NEO' started by Maurice, Mar 26, 2016.
  1. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    When I verify or upload a simple sketch to my Neo I get several errors. Did I miss a configuration setup step?
    Arduino: 1.6.8 (Linux), Board:"UDOO Neo (Cortex M4)"
    WAARSCHUWING: Categorie '' in bibliotheek SPI is niet geldig. Wordt gewijzigd naar 'Uncategorized'
    WAARSCHUWING: Categorie '' in bibliotheek Wire is niet geldig. Wordt gewijzigd naar 'Uncategorized'
    Warning: platform.txt from core 'UDOO NEO (iMX6 SoloX)' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
    cc1plus: error: to generate dependencies you must specify either -M or -MM
    exit status 1
    Error compiling for board UDOO Neo (Cortex M4).
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
  3. Maurice
    Oct 13, 2015
    394
    87
    Installed 1.6.5, but it tries to upload it to com1...
    I've changed it to the only other available option /dev/ttyACM0, but this doesn't work either because "/dev/ttyACM0" (Port busy)
  4. waltervl
    I suppose you run arduino ide on your PC. According the installation manual you do not have to select a port, so I think you have to install it again.
    Does the IDE on the Neo work?
  5. Maurice
    Oct 13, 2015
    394
    87
    If I don't change it it tries to use com1:, which fails very early on Linux. ttyACM0 was named by a Arduino page itself and I've tried the Arduino IDE with sudo and without sudo.
    Arduino IDE through the web interface works, a great way for quickly starting with stuff. For a bit longer development a real IDE would be much better.
  6. waltervl
    Do you have a Linux pc you are working on and have that PC connected to the Neo?
    There is a full blown Arduino IDE preinstalled on the Linux side of the Neo. Connect to your Neo with vnc viewerhttp://www.udoo.org/docs-neo/Basic_Setup/Remote_Desktop_(VNC).html to access it. Or connect a HDMI monitor/TV and keyboard and mouse to use the Neo without interaction with another PC.
  7. Maurice
    Oct 13, 2015
    394
    87
    Yes, the Linux is connected to the Neo with the USB cable. Using Arduino IDE over VNC is of course an improvement, but I would like to use a local IDE, also because I have a Quad which I would like program the Arduino on.
  8. waltervl
  9. Maurice
    Oct 13, 2015
    394
    87
    Yes, I use a 64 bit Ubuntu. I did the apt-get, but Ubuntu didn't find any of these packages.
