Hello friends! I'm using the UDOO (with Ubuntu) for a home automation project. I was previously using the Raspberry Pi, but needed a few more features, and the UDOO fit the bill (and I conveniently had it from the kickstarter campaign). Among other things, I have a BlinkyTape connected to the UDOO via USB. I wrote new firmware for it that stores several LED patterns on the tape, and sending a serial command over the USB TTY connection triggers the selected pattern to play. I've been using this without a problem on the Raspberry Pi. The BlinkyTape uses an Atmel 32U4 with the Arduino Leonardo bootloader, and is identified as such. When I plug the BlinkyTape into the UDOO, it's clearly detected as a Leonardo (see dmsg output below), but it appears to be detected as an HID instead of a USB Serial device. This is odd, because when I plug it into a Windows machine, or a raspberry pi (running raspbian) it correctly identifies as USB serial and I can send it serial commands. Since it isn't detected as a USB serial device, a /dev/tty* device is not associated with it, and I can't send serial commands. It also does not appear in the Arduino 1.5 of 1.0.5 IDE port menu listings (it is greyed out). Do you have any idea why this might be happening!? Thanks! dmsg Output: [ 188.417822] usb 2-1.2: new full speed USB device number 11 using fsl-ehci [ 188.538518] input: Arduino LLC Arduino Leonardo as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.2/2-1.2:1.2/input/input4 [ 188.541804] generic-usb 0003:2341:8036.0007: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-fsl-ehci.1-1.2/input2 -Jeremy
Re: Arduino Leonardo connected via USB is not detected as TT Got it working! Here's how: Got it working! Yay! Here's how. You need to recompile the kernel with usb cdc acm support. sudo apt-get install build-essential git libncurses5-dev git clone https://github.com/UDOOboard/U-Boot_Unico-2013.git cd U-Boot_Unico-2013/ make -j5 tools sudo cp tools/mkimage /usr/local/bin cd /usr/src/ sudo git clone https://github.com/UDOOboard/Kernel_Unico kernel cd kernel sudo make ARCH=arm UDOO_defconfig sudo make ARCH=arm menuconfig Device Drivers —> USB support –> USB Modem (CDC ACM) support -> Then Exit and Save when asked. sudo make sudo make modules_install sudo make install sudo make -j5 uImage sudo mv /boot/uImage /boot/uImage_backup sudo cp arch/arm/boot/uImage /boot/ sudo reboot modprobe cdc_acm sudo vim /etc/modules add "cdc_acm" no quotes. sudo usermod -a -G dialout ubuntu logout and back in
