Arduino Libraries on UDOO NEO: tell us what to port
Discussion in 'UDOO NEO' started by Andrea Rovai, Jan 21, 2016.
  1. waltervl
    Now that I have read the manual it is about how to compile the serial library.
    But how to port for example the servo library? Are there any alterations to the source needed to be compliant with the Neo, or is it just compiling the c source on the Neo doing the trick? I am new to this so just wondering. I have the feeling it is not that simple but perhaps I am thinking too much.[emoji2]
    jrullan likes this.
    @AndreaRovai So Softserial is added to the list. Is there an update on the total planned list and time planning?
  3. Aimar Dynamik
    Aimar Dynamik New Member
    May 3, 2016
    28
  4. waltervl
  5. waltervl
  6. gefla
    gefla New Member
    Oct 28, 2013
    That's very useful documentation. It would be even better if it stated or pointed at the reasons why particular operations (which exactly, just pinMode()/digitalWrite() or others as well?) aren't working. Could you provide some insight?
    I'm curious if there's a possible solution that doesn't require porting lots of external libraries and allows the majority to be used unmodified.
  7. Andriy
    Andriy Member
    Nov 10, 2015
    30
    I wanted use Grov- Air Quality Sensor V1.3 with udoo neo , but cannot use example from their site ant github. Error (ISR (TIMER2_OVF_vect ). Why? Thanks.
  8. waltervl
  9. JackSilb
    JackSilb Active Member
    Nov 3, 2015
    100
    32
    Andrea:
    - Firmata
    It depends on other libraries too.
    -Jack
  10. Tomatoe49
    Tomatoe49 New Member
    Aug 15, 2016
    Neopixels - The Neo is particularly suited to solving problems for Neopixels. Because the Neopixel code is bitbanging the data out, with other boards it is hard to talk to the ARM that is controlling the lights from "the real world" such as a web page. With the shared memory, it should be easy to poke values in from the web side and let the M0 read them as its convenience.
    I bought the Neo specifically for this use and was hoping to sell a few.
  11. Constant Zion
    Constant Zion New Member
    Sep 16, 2016
    Hey Everybody!
    I'm new here, and globally new to Arduino, but i know how to mess with a computer and a soldering iron (separately)
    I'm wondering if an Adafruit-Motor-Shield-library port would be possible, or maybe someone more experienced could show me how to do it myself. I've come across some "tips" on porting around here, but unfortunately they're out of range for me.
    Thanks in advance!
  12. waltervl
    First be sure your shield is compatible with the Neo as the Neo is 3.3V. will your shield accept that ( I doubt that if you have version V1)? V2 should work but is controlled by I2C instead of pwm pins so completely different library.
  13. PLouy
    PLouy New Member
    Jul 12, 2017
    Does AccellStepper Library work with the M4? Using digital pins to control step, direction, resolution etc sent to a driver IC?
  14. waltervl
    If it compiles chances are increasing it will.
  15. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    You would need to fix up the library to use a hw timer on the M4 side to get an accurate step interval.
  16. gheesung
    gheesung New Member
    Apr 16, 2017
    12
    Radiohead libraries
