BIOS Update... FAIL??
Discussion in 'UDOO X86' started by Ascanio, Apr 22, 2017.
  1. Ascanio
    Ascanio New Member
    Jan 3, 2014
    10
    So I received my new x86 board. I'm happy and all, and when I start going through the installation process of an OS ( Windows 10 in my case ) I remember just how DIY-unfriendly everything UDOO really is.
    Ok I don't want to be a complainer, so let's get to business... I now have had the board sitting for 15 minutes with the Insyde H20 Flash Firmware Tool. I don't think this is normal, it should have completed the BIOS update by now, WTF.
    Just to add why I knew this ( also this... ) would have gone wrong: right before the red box with the text "Please do not remove the AC power", I read a DOS line ( yes, I have run the updater from the DOS, since I need to update to be able to install the friggin OS ):
    Error: Allocate Physical Memory failer. ( buffer2 )
    Now the only live thing I see is the flashing underline at the bottom left corner of the screen. Nothing else has happened.
    What the hell am I supposed to do now?
    p.s. sorry for the attitude but I am really frustrated at UDOO, I have purchased all their boards, and each and every time it has been a nightmare to get them ( sort of ) working.
  2. Ascanio
    Ascanio New Member
    Jan 3, 2014
    10
    OK I powered it off, it booted again, and BIOS has remained 1.01.
    There is clearly something wrong with the board.
    Will try installing Windows 10 from USB instead of SD ( thanks for misleading and making me waste 6 hours trying to get Windows on the SD card..... )
  3. Ascanio
    Ascanio New Member
    Jan 3, 2014
    10
    Windows 10 installed from a USB stick. Is now running. I am performing some tests, then will try to update the BIOS from Windows.
  4. mkopack
    mkopack Member
    451
    Remember that you need to do it from a CMD that was Run as Admin..
  5. Ascanio
    Ascanio New Member
    Jan 3, 2014
    10
    Thanks! Will keep that in mind :)
    Have to say the performance of this board is pretty astounding!
    Andrea Rovai likes this.
  6. David Rad
    David Rad New Member
    Jan 10, 2019
    Did the DOS problem from bios 1.01 get fixed?
    I have:
    Error: Allocate Physical Memory failer. (buffer2)
    Using:
    FreeDOS
    Is there a bootable BIOS flash file available?
    (Im currently running FreeELEC with kodi but need to upgrade the bios on my 2x boards.
