Bluethoot tricks
Discussion in 'UDOO NEO' started by Pietro Grossi, Nov 27, 2015.
  1. Pietro Grossi
    Pietro Grossi New Member
    Oct 22, 2015
    Hi folks I'd like to share with you some tricks I found over internet about bluethoot fixed on udoo neo. First I seen that with the beta 5 the bluethoot device is recognized at startup and available to connect to other devices but , and I believe this is another issue, it becomes not available if not used asap after the boot. Anyway I tried to connect my JBL loud speaker bluethoot device to udoo and I received the following error:
    Result: Connection Failed: Stream Setup Failed
    After some google research I found the following link tha explain how to fix the problem:
    https://zach-adams.com/2014/07/bluetooth-audio-sink-stream-setup-failed/
    I performed both steps and the loud speaker runs as you can see from the attached pdf screenshot file.
    I hope this help.
    Thanks
    Pietro
    Zek and Andrea Rovai like this.
