Bluetooth Arduino side
Discussion in 'UDOO NEO' started by nomida, Aug 4, 2016.
  1. nomida
    nomida New Member
    Feb 22, 2016
    15
    Hi all,
    I quick question, can I use the Udoo bluetooth with Arduino, or I need to add a shield?
    I know, and I have already tried to send the data through serial comm /dev/ttyMCC and I used python to send bluetooth packet. But this time I wish to avoid use A9 and send directly the data through BLE
    Thanks
    There is no known fix. Someone with deeper knowledge would hopefully know a way to connect UART3 to the Arduino side.
    As a quick fix use something like this and connect it to Serial0 on the Neo Arduino.
  3. nomida
    nomida New Member
    Feb 22, 2016
    15
    Cool, yes I had someway to fix the problem.
    I am going to use this:
    https://www.adafruit.com/products/2479
    I tried the to compile against the adafruit library and I had to modify in a couple of points the source code.
    Late I will try if it will work.
    BTW, why did you call Serial0 instead of Serial1 as in Arduino ?
    cheers
