Boot using DVI rather than HDMI
Discussion in 'UDOO X86' started by oodu, Apr 25, 2017.
  1. oodu
    oodu New Member
    Apr 25, 2017
    Is it possible to boot using the DVI connection instead of using the HDMI connection?
    If possible, which DVI connection to use, and if there is any settings to change?
    Tried doing it from either DVI connection but it didn't work and can't seem to find any settings to enable that.
    Thanks!
  2. onek
    onek New Member
    May 30, 2016
    18
  3. oodu
    oodu New Member
    Apr 25, 2017
    My apologies.
    You are right I meant the mini dp ports and not dvi.
    Thanks
  4. wsian
    wsian New Member
    Apr 2, 2017
    18
    Yes, you can boot from mini dp as the main screen.
    By default, output to hdmi, dp#1, dp#2 are all enabled in bios.
    onek likes this.
