bossac patch
Discussion in 'Arduino IDE' started by Andy1988, Jul 26, 2014.
  1. Andy1988
    Andy1988 New Member
    Jul 26, 2014
    Hi all,
    I'd like to know what exactly you guys patched in bossac. I know that if you want to program the SAM3X from the iMX6 itself, I need to assert two GPIOs attached to ERASE and RESET. But what did you do for external programming?
    Unfortunately it seems that you only deliver the bossac binaries itself. Is the patch published somewhere?
  2. gfasino
    gfasino New Member
    Jun 27, 2014
    13
    the bossac file is made for program the UDOO arduino part with the arduino IDE.
    You have to insert the bossac file into hardware/tools folder of arduino IDE.
    However you can use the patch arduino IDE downloadable here:
    http://udoo.org/download/files/arduino- ... DOO.tar.gz
  3. Andy1988
    Andy1988 New Member
    Jul 26, 2014
    I know that. I'd like to know what exactly was patched IN the bossac application.
    bossac itself is a regular open source application. Now licensed under BSD, before that it was licensed under GPL.
    https://github.com/shumatech/BOSSA
    I'm curious what you guys patched in that application.
  4. Halloween
    Halloween Member
    Jul 23, 2014
    33
    Yes, it seems you need also a modfied bossac file with a booted Android, because it's working with booted Udoobuntu only.
    kenr likes this.
  5. pklaus
    pklaus New Member
    Dec 19, 2013
    Me too, I would like to know that. Without the source code / a diff you simply cannot be sure what happens there. The whole concept of open sourcing the Arduino environment is a farce if you need a binary blob to upload the file to the SAM3X in the end! Please let us know what you did there.
  6. Andy1988
    Andy1988 New Member
    Jul 26, 2014
    I recently reverse engineered what they are doing there. It's a combination between BOSSA patches and a custom kernel module.
    BOSSA patch: https://github.com/UDOOboard/BOSSA/comm ... 15db573229
    Kernel module: https://github.com/UDOOboard/Kernel_Uni ... udoo_ard.c
    What they do is, they are using DTR and RTS on the serial port to send commands to the linux kernel which resets or erases the SAM3U via GPIO lines. The kernelmodule just waits for the DTR and RTS lines to wiggle around and then controls the ERASE and RESET pins on the SAM3U via the gpio subsystem. RTS is the clock signal and DTR is a data bit for the protocol.
    This function here (https://github.com/UDOOboard/BOSSA/comm ... 0b4d78R102) 'authenticates' with a token which is 0xA5A5 and then sends 0xF as a following data byte. The kernel module then erases and resets the SAM3U. Before it resets, it disabled some UART and/or GPIO lines.
    Another function here (https://github.com/UDOOboard/BOSSA/comm ... 0b4d78R142) again sends the auth-token and then 0x0 as the following data byte. The kernel then reenables the UART and the GPIO lines it disabled beforehand.
    You can look up all the used pins in the schematic. Initially there was a small PIC inteded for performing exactly that task, but it's not populated on the boards. At least not on mine. Now they are doing all that in the said kernel module I linked to above.
  7. estebanSannin
    estebanSannin New Member
    Feb 21, 2015
    11
    Andy1988 thanks for this post... very usefull!
  8. Itachi
    Itachi New Member
    Jun 14, 2015
    10
    Hello,
    I got UDOO Quad. I am trying to program it externally using PC(windows 8.1) using Arduino IDE(version 1.5.4). I did patch up and connected UDOO(CN6) to my PC using micro usb with J18 unplugged.When I try to upload basic Blink code it is displaying the error "SAM-BA operation failed".
    [​IMG]
    When i deleted the cygwin1.dll file from" C:\Program Files (x86)\Arduino\hardware\tools " and trying to upload the code it is not displaying the errors but the code is not uploading.
    [​IMG]
  9. Andrea Rovai
    Hi there all,
    we don't want to "hide" the bossac sources, we'll publish them as soon as we got a calmer moment :) Please be patient in the meanwhile.
