Bugs of Gaphic driver ???
Discussion in 'Linux Ubuntu' started by vivagonna, Dec 28, 2013.
  1. vivagonna
    vivagonna New Member
    Oct 17, 2013
    10
    It seems that the Gaphic driver of ubuntu12.04 has some problems on my board(UDOO Dual). The "Gaphic driver"opinion in the "system information" is blank, and the OpenGL seems not work. I can't paly video with media player as well. Anyone could help? Thanks.(I had ask one of my friends who has Qual, but his doesn't have the problem.)
  2. miousername
    miousername New Member
    Jun 23, 2013
    73
    Maybe you have installed some application with apt-get.
    Launch this command:
    udoo#/opt/gpulink-x11.sh
    udoo#reboot
    And then try again!
  3. vivagonna
    Oct 17, 2013
    10
    Thanks for your kind reply.
    I launched the commands as you said, like this:
    [​IMG]
    But after reboot, It seems not work. I tried twice, all like this.
    [​IMG]
    Did I miss anything?
    Thank you
  4. miousername
    Jun 23, 2013
    73
    Ok,
    If you want to check that opengl works you have to launch this command, open a terminal and then:
    $glxgears
    Post the result of this command:
    $glxinfo | grep -i direct
  5. vivagonna
    Oct 17, 2013
    10
    Thank you very much for reply. I just try the command
    the result is
    Error: couldn't find RGB GLX visual or fbconfig
    I preformed that command through MS Remote Desktop on my laptop.
    I searched the result and it seems to be problems with GPU driver, but I didn't find an effective way to solve that. What should I do? ( I did have reinstalled the system before, but dose not work. ) Looking forward to effective method. Thanks a lot!
  6. punk45rock
    punk45rock Member
    Dec 21, 2013
    32
    Try running
    sudo usermod -a -G video <username>
    then rebooting.
  7. vivagonna
    Oct 17, 2013
    10
    Thanks for your reply. I tried but it still not work. It seems that no Qual has this problem, maybe it's a bug to Dual? Maybe I should wait for Debian :roll:
  8. punk45rock
    punk45rock Member
    Dec 21, 2013
    32
    Did you replace <username> with the username you use to log in to Ubuntu? I only have a quad so I can't test this myself.
    I did use the Debian armhf image from the download section a few days ago and I think opengl was working better than ubuntu out of the box.
  9. vivagonna
    Oct 17, 2013
    10
    Yeah, I replace <username> with ubuntu, as I have never changed it. The command did not make any error, but the problem is still there. As I'm new to linux, I'm still waiting for a stable version of Debian. Thank you again! :D
  10. miousername
    Jun 23, 2013
    73
    You have to launch the command I said before in a graphical terminal inside desktop.
    If you launch in a remote shell it will give an error because the procedure is quite different.
