Building Android 6.0.1 for Seco A62
Discussion in 'SECOSBC-A62' started by MatteoZ, Jul 8, 2017.
  1. MatteoZ
    MatteoZ New Member
    Apr 24, 2017
    I post here some additional packages and a file patch I had to apply to compile Android 6.0.1 for the target Seco A62 Quad (a62_6dq-eng) on a Ubuntu 14.04.05 LTS 64bit Desktop PC.
    My bild was based on the sources provided by https://github.com/UDOOboard/android_udoo_platform_manifest -b android-6.0.1
    On top of the steps described at the links:
    http://download.udoo.org/files/a62/Android/A62_instructions_Android_6.0.x_source.txt
    http://www.udoo.org/docs/Advanced_Topics/Compile_Android_From_Source.html
    I had to install the following additional packages on Ubuntu 14.04:
    libxml2-utils lib32stdc++6 liblz4-dev
    The file external/lz4/lib/Android.mk had to be modified, adding the following lines at the end
    (this was suggested by another post in the Udoo.org Android forums).
    include $(CLEAR_VARS)
    LOCAL_MODULE := liblz4-static
    LOCAL_SRC_FILES := $(liblz4_src_files)
    LOCAL_MODULE_TAGS := optional
    include $(BUILD_STATIC_LIBRARY)
    After having completed those additional steps, I was able to complete the make process without errors, including some custom modifications of the 3.14 kernel code I wanted to apply.
    modjo likes this.
  2. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Thanks for the share ;)
