Hi friends, Some people want c++ compile with eclipse. I will explain how to install c/c++ plugin in eclipse. You can not use eclipse plugin module. When I try download plugin on eclipse I get error everytime. I do not know why I get error. For this reason, you can not use eclipse plugin manager. First of all, you should run Synaptic Package Manager and write eclipse and you can see “eclipse-cdt” package after that right click and select “mark for Installation”. Finally, you should click “Apply”. Synaptic Package Manager will install four package with eclipse-cdt. You should allow installation. If you can install successfully, you can open eclipse. I explained how to install eclipse other topic. 1-)Open eclipse click File → New → Project and you will see this page; 2-) Select C++ project and click Next. 3-) Click Finish and you can write code and Build it.(Project → Build All) Finally you can Run it
Nice. There's also Netbeans but I'm betting it won't run as well (it usually seems to be more of a resource hog than Eclipse, although I really prefer Netbeans from a user perspective...) I really wish Netbeans would include a good Python Language support kit plugin as well...
Thanks for the tutorial. can you help me, i'm trying to send data from eclipse c++ to sam3x (Arduino) but nothing happened, it don't send anything, Maybe i'm configuring in a wrong way.
Hi, I just received the quad board. Need to perform C++ programming on the board n compiled. Would like to ask which package/version you install for Eclipse? In www.eclipse.org/download have a lot package to choose. Please provide me the actual link download. Then I will follow your tutorial above on the plug in for cdt. Thanks
Hi, you have to download eclipse which is compatible with arm cpu. I do not know which package support arm architecture. However, you can install eclipse from Lubuntu Software Center.
