CanOpen communication with Qt on udoo Neo
Discussion in 'UDOO NEO' started by Sassus-Bourda, Mar 17, 2016.
  1. graugans
    Sep 17, 2015
    328
    141
    What Ubuntu Version are you using?
  2. Sassus-Bourda
    Sassus-Bourda Member
    Dec 21, 2015
    42
    I use an ubuntu 14.04
  3. graugans
    Sep 17, 2015
    328
    141
    I try to set-up a VM to test.
  4. Sassus-Bourda
    Dec 21, 2015
    42
    Ok I did the same with a clean environment !
    Now when I build I have this error :
    c:command not found
    and always this one too :
    Cannot read /opt/poky/2.1/sysroots/cortexa9hf-neon-poky-linux-gnueabi/usr/lib/qt5/mkspecs/oe-device-extra.pri: No such file or directory
    Just to be sure I have to put in the qtcreator.sh this line before the
    #! /bin/sh:
    source /opt/poky/2.1/environment-setup-cortexa9hf-neon-poky-linux-gnueabi
    graugans likes this.
  5. Sassus-Bourda
    Dec 21, 2015
    42
    Hi graugans,
    Any advance on your side?
    For my part I did some modifications :
    First in the qtcreator.sh I add the qmake variable I follow this tuto http://wiki.wandboard.org/index.php/Setup_QT_creator_for_developing_QT_apps_on_wandboard
    I also modify the qmake.conf on location /home/pierre/Qt/5.6/Src/qtbase/mkspecs/linux-arm-gnueabi-g++ I just put the complete path for compiler of toolchain.
    My first errors is no longer display but now Qt said "Failed to start program. Path or permissions wrong?"
    Any ideas?
  6. Sassus-Bourda
    Dec 21, 2015
    42
    Finally it's work on my udoo not on my pc but no matters for now !
    The new problem is that when I try to build the serialbus example the library libQt5SerialBus.so.5 is not found.. Where can I download just the .so file because I don't want install Qt on my board!
  7. graugans
    Sep 17, 2015
    328
    141
    You followed the instruction from my post with the image link?.
  8. Sassus-Bourda
    Dec 21, 2015
    42
    It's good I can cross-compile !!
    Thank you very much for your help!
    One last question my wifi doesn't works with the image I have on interface file the line "iface wlan0 inet dhcp" but no connections..
    Any idea?
  9. graugans
    Sep 17, 2015
    328
    141
  10. Sassus-Bourda
    Dec 21, 2015
    42
    So everything work fine thanks for your help graugans!
    I can launch the qserialbus example on my udoo board but now I have some new issues..
    First when I connect the board :
    "SocketCanBackend: No such configuration as 4 in SocketCanBackend"
    Cannot apply parameter: QCanBusDevice::ConfigurationKey(BitRateKey) with value: QVariant(int, 500000)
    And after few frames send I get the following error :
    "No buffer space available"
    Futhermore I don't receive the frame send by the board on my pc and my pc doesn't receive the frame send from the board..
    Thanks in advance for your help
  11. graugans
    Sep 17, 2015
    328
    141
    Sorry, I did not yet managed to attach an CAN client to test.
  12. Sassus-Bourda
    Dec 21, 2015
    42
    Ok but I thought Modjo have already succeed, are you in contact with him?
    Do you think you will test this part soon?
  13. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
  14. Sassus-Bourda
    Dec 21, 2015
    42
    Yes I already follow this tuto and I succeed with the udoobuntu distribution.
    So with poky distriution I launch a command prompt with putty on my pc and dump the frame with a second user and with udoo I send a frame as root.
    The result is positive but no way with no loopback
    Thanks for your answer
  15. graugans
    Sep 17, 2015
    328
    141
  16. graugans
    Sep 17, 2015
    328
    141
  17. Sassus-Bourda
    Dec 21, 2015
    42
    Screen is not a part of Qt image unfortunately but I dit it with another ssh session see my previous post.
    But no result when I try to send frame to another client
  18. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    see after a class that i create to use CAN on NEO :
    QCan.h
    and
    QCan.cpp
    Let me know if it can help you
  19. Sassus-Bourda
    Dec 21, 2015
    42
    I create a new Qt projet with that classe ?
    Why use this classe, the QSerialBus class is not working on Neo?
    Thanks for your help
  20. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    I didn't rewrite QserialBus, it just to show you how i use this class with QProcess to use CAN on NEO. And yes you could create a new project with this class !
