Hi, I recently installed Ubuntu 14.04 arm, gstreamer, ffmpeg, opencv etc.. However I struggle to use the onboard camera. When typing: gst-launch-0.10 mfw_v4lsrc ! ffmpegcolorspace ! ximagesink i get following: MFW_GST_V4LSRC_PLUGIN 3.0.11 build on Sep 4 2014 20:20:26 Setting pipline to PAUSED ... ERROR: Pipeline doens't want to pause. Setting pipeline to NULL ... Freeing pipeline ... Am I missing a driver or something?
That's it, you miss the driver because you are using a different kernel and file system. Check if into the Kernel there are the MIPI CSI drivers. Moreover in the filesystem the libraries gstreamer by Freescale must be present.
