Can't play videos with QT (Qmediaplayer, Udoobuntu 2)
Discussion in 'UDOO NEO' started by closx, May 15, 2019.
  1. closx
    closx UDOOer
    May 2, 2019
    13
    Hello everyone, me again!
    I finally built my QT5 application for Udoobuntu 2 (I know there is not so much source around for that. So I can help anyone with that.). My application is a basic Video Player application which depends on Qmediaplayer.
    When I run glmark2 or something else that tests OpenGL ES2, it works without problems.
    But when I run my application or any QT application uses OpenGL (as hellogl_es2), It gives the error following, "Unable to find an X11 visual which matches EGL config".
    Full output;
    root@udooneo:/usr/lib/arm-linux-gnueabihf/qt5/examples/opengl/hellogl_es2# ./hellogl_es2
    xkbcommon: ERROR: x11: failed to get keymap from X server: unmet condition in get_explicits(): wire->keycode >= keymap->min_key_code && wire->keycode <= keymap->max_key_code
    Warning: EGL suggested using X Visual ID 33 (RGB565) for EGL config 5 (RGB444), but this is incompatable
    Unable to find an X11 visual which matches EGL config 5
    Warning: EGL suggested using X Visual ID 33 (RGB565) for EGL config 1 (RGB444), but this is incompatable
    Unable to find an X11 visual which matches EGL config 1
    Segmentation fault
    evaloverde likes this.
  2. closx
    closx UDOOer
    May 2, 2019
    13
    Up! It past three days, and still I cannot find the solution guys. Please help!
  3. closx
    closx UDOOer
    May 2, 2019
    13
    Up! Guys, it has been 16 days. Still could not solve the problem. Help please!
  4. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Hi @closx , I think it more useful if you share even:
    - How you compiled QT
    - Your code
