Can't update Intel via Linux [SOLVED]
Discussion in 'UDOO X86' started by Ryan Lewkowicz, Aug 5, 2017.
  1. Ryan Lewkowicz
    Ryan Lewkowicz New Member
    Aug 4, 2017
    19
    Sorry for opening so many threads. I don't know where else to go for some of this. The intel stuff at least I think is proprietary so I don't think I can open like a github issue. So on ubuntu 16.04 the intel update utility fails (https://01.org/linuxgraphics/downloads/update-tool). The reason I was hoping this would work, is because the udoo will not handshake with my benq monitor (2k gaming monitor) even after boot. It makes things a really big pain for me trying to work on this board.
    \U0001f55b update_action
    \U0001f55b Finished : Downloading from us.archive.ubuntu.com/ubuntu [ ] \u23f2
    src/package-manager-ubuntu.c/on_transaction_signal: Received transaction signal PropertyChanged from :1.104 with ('ExitState', <'exit-failed'>)
    \U0001f55b on_transaction_signal
    \U0001f55b Finished : Downloading from us.archive.ubuntu.com/ubuntu [ ] \u25e6
    I tried their 16.04 package and also compiled the latest one from source. My package manager seems to be in working order. How can I get help on this?
  2. Ryan Lewkowicz
    Aug 4, 2017
    19
    [SOLVED]
    So I did a lot of stuff, but I'm pretty sure this was what fixed my issue.
    First lets take care of the package manager:
    You might not have to remove everything, you probably just need the key. I think too, I had to re add the key for google.
    sudo apt-get clean
    cd /var/lib/apt
    sudo mv lists lists.bak
    sudo mkdir -p lists/partial
    sudo apt-get clean
    #Now realistically if you're on 16.04 you just need the 4th one, but I add them all just for fun cause why not?
    wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
    wget --no-check-certificate https://download.01.org/gfx/RPM-GPG-KEY-ilg-2 -O - | sudo apt-key add -
    wget --no-check-certificate https://download.01.org/gfx/RPM-GPG-KEY-ilg-3 -O - | sudo apt-key add -
    wget --no-check-certificate https://download.01.org/gfx/RPM-GPG-KEY-ilg-4 -O - | sudo apt-key add - #You may just need this
    sudo apt-get update
    Cool. Packages should be good.
    Then, add this ppa or else it gets mad later on:
    #https://launchpad.net/~paulo-miguel-dias/+archive/ubuntu/pkppa
    sudo add-apt-repository ppa:paulo-miguel-dias/pkppa
    sudo apt-get update
    Then weep gently at all the time you're burning
    As an aside, I don't know that this was even my issue. I had to like force the monitor active via arandr. I've never had to do that. So Idk if I missed it last time, or this fixed it.
    MrGarapablo likes this.
