I want to wire up a fan but the plug header on the board is tiny and nothing like any other boards fan header. Does anyone have a close up photo of the fan plug or a possible form factor?
All the Udoo X86 connector details are in the user manual pdf that you can download here or here Also @Brad figured some buying details (including wired connector) out here
Couldn't find any info in the manual I had already looked there first before posting. I guess they want you to buy the fan from them rather then diy. Thanks for the link to Brad's post. Looks like I will go that route.
Just finished wiring a fan using a 1.25mm plug from http://www.ebay.com/itm/152340772599 (I ordered 4P so i had to snip one box + same seller has 1.25mm pin with wire and sata power connector) the thing is, the top view in manual page 33 is wrong, pin1 is actually on the other side (judging from pins being closer to board edge) the correct wiring can be seen in at 50 sec (black : gnd, red :+12, rest : tacho) so i had to swap gnd with tacho and got it working
They have shown the details of connector and can also use for fan connector . Its upto us how we need to use it as per our convinience.
