CPU Temp in Linux
Discussion in 'UDOO BOLT' started by Andy Carlson, Aug 31, 2019.
  1. Andy Carlson
    Andy Carlson New Member
    Apr 22, 2019
    Hi All.
    I received my Bolt last night. I have been watching the temps, because of some of the problems I've seen in the forums. My temperatures, have been great, but I realized that lm_sensors doesn't say CPU temp. I was assuming the K10temp was CPU, and it does go up if I run stress cpu hog threads. Here is a screenshot of my sensors - which one is CPU? Thanks.
    DJVT likes this.
  2. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    interested in the same, it seems the k10 (cpu?) and amdgpu-pci :: temp1 (gpu?) run about the same temp when i was doing a 4 thread stress test. it makes sense as they are a single package i suppose.
    is there value in monitoring separately? or will they always be roughly the same
  3. Hal
    Hal UDOOer
    Dec 1, 2018
    I believe the first sensor is in the Intel WiFi card (it seems to run hotter than the non-stressed CPU), the second is the power adapter, the third is the GPU and last is the CPU. But to be honest I am not 100% sure.
  4. DJVT
    DJVT UDOOer
    Nov 28, 2019
    16
    Hello @Andy Carlson ,
    would you please tell us which software you are using to check the cpu temperatures? I am using and have to use Ubuntu 18.04 ...
    I tried lm-sensors, but it didn't find any sensors.
    Cheers,
    DJVT
  5. Andy Carlson
    Apr 22, 2019
    I used lm_sensors also, but it was on Fedora.
    DJVT likes this.
  6. Zgembo
    Zgembo UDOOer
    Sep 21, 2019
    49
    27
    @DJVT Just use more recent kernel and you will be able to access ivi sensors;
    root@bolt:~# lsb_release -i -r
    Distributor ID:    Ubuntu
    Release:    19.10
    root@bolt:~# uname -a
    Linux bolt 5.3.0-24-generic #26-Ubuntu SMP Thu Nov 14 01:33:18 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
    root@bolt:~# sensors
    amdgpu-pci-0500
    Adapter: PCI adapter
    vddgfx:           N/A
    vddnb:            N/A
    edge:         +42.0°C  (crit = +80.0°C, hyst =  +0.0°C)
    acpitz-acpi-0
    Adapter: ACPI interface
    temp1:        +42.5°C  (crit = +99.0°C)
    temp2:        +10.0°C  (crit = +125.0°C)
    k10temp-pci-00c3
    Tdie:         +42.5°C  (high = +70.0°C)
    Tctl:         +42.5°C
    DJVT likes this.
  7. DJVT
    DJVT UDOOer
    Nov 28, 2019
    16
    Thank you @Zgembo,
    unfortunately I am tied to Ubuntu 18.04 LTS and Kernel 5.0 because of some software and hardware I am using.
    Update, acpi works on 18.04 with 5.0 Kernel:
    $ sudo apt install acpi
    $ acpi -t
    Thermal 0: ok, 10.0 degrees C
    Thermal 1: ok, 46.5 degrees C
    idk what Thermal 0 is though. It is 10°C constantly, so probably misinterpreted data...
