Creating a Wireless Access Point
Discussion in 'Debian' started by 2xyo, Jan 8, 2014.
  1. 2xyo
    2xyo New Member
    Nov 11, 2013
    Hi everyone,
    Does Udoo board support the "AP" mode to do a wifi access point with hostapd?
    Does someone can do the following commands to check:
    $ sudo iw list
    $ sudo iwconfig wlan0 mode master
    Thanks !
  2. delba
    1,064
    We're trying to do exactly the same thing with hostapd. A step by step tutorial will be available asap.
  3. 2xyo
    2xyo New Member
    Nov 11, 2013
    Nice !
    How do you enable master mode on wlan0 ?
    I tested the following commands:
    iw list
    root@udoo-debian-hfp:~# iw list
    Wiphy phy0
    	Band 1:
    		Capabilities: 0x172
    			HT20/HT40
    			Static SM Power Save
    			RX Greenfield
    			RX HT20 SGI
    			RX HT40 SGI
    			RX STBC 1-stream
    			Max AMSDU length: 3839 bytes
    			No DSSS/CCK HT40
    		Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
    		Minimum RX AMPDU time spacing: 2 usec (0x04)
    		HT RX MCS rate indexes supported: 0-7, 32
    		TX unequal modulation not supported
    		HT TX Max spatial streams: 1
    		HT TX MCS rate indexes supported may differ
    		Frequencies:
    			* 2412 MHz [1] (20.0 dBm)
    			* 2417 MHz [2] (20.0 dBm)
    			* 2422 MHz [3] (20.0 dBm)
    			* 2427 MHz [4] (20.0 dBm)
    			* 2432 MHz [5] (20.0 dBm)
    			* 2437 MHz [6] (20.0 dBm)
    			* 2442 MHz [7] (20.0 dBm)
    			* 2447 MHz [8] (20.0 dBm)
    			* 2452 MHz [9] (20.0 dBm)
    			* 2457 MHz [10] (20.0 dBm)
    			* 2462 MHz [11] (20.0 dBm)
    			* 2467 MHz [12] (20.0 dBm) (passive scanning, no IBSS)
    			* 2472 MHz [13] (20.0 dBm) (passive scanning, no IBSS)
    			* 2484 MHz [14] (20.0 dBm) (passive scanning, no IBSS)
    		Bitrates (non-HT):
    			* 1.0 Mbps
    			* 2.0 Mbps (short preamble supported)
    			* 5.5 Mbps (short preamble supported)
    			* 11.0 Mbps (short preamble supported)
    			* 6.0 Mbps
    			* 9.0 Mbps
    			* 12.0 Mbps
    			* 18.0 Mbps
    			* 24.0 Mbps
    			* 36.0 Mbps
    			* 48.0 Mbps
    			* 54.0 Mbps
    	max # scan SSIDs: 4
    	max scan IEs length: 2257 bytes
    	Coverage class: 0 (up to 0m)
    	Supported Ciphers:
    		* WEP40 (00-0f-ac:1)
    		* WEP104 (00-0f-ac:5)
    		* TKIP (00-0f-ac:2)
    		* CCMP (00-0f-ac:4)
    	Available Antennas: TX 0 RX 0
    	Supported interface modes:
    		 * IBSS
    		 * managed
    		 * AP
    		 * AP/VLAN
    		 * WDS
    		 * monitor
    	software interface modes (can always be added):
    		 * AP/VLAN
    		 * monitor
    	interface combinations are not supported
    	Supported commands:
    		 * new_interface
    		 * set_interface
    		 * new_key
    		 * new_beacon
    		 * new_station
    		 * set_bss
    		 * authenticate
    		 * associate
    		 * deauthenticate
    		 * disassociate
    		 * join_ibss
    		 * remain_on_channel
    		 * set_tx_bitrate_mask
    		 * action
    		 * frame_wait_cancel
    		 * set_wiphy_netns
    		 * set_channel
    		 * set_wds_peer
    		 * connect
    		 * disconnect
    	Supported TX frame types:
    		 * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
    		 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
    		 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
    		 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
    		 * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
    		 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
    		 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
    	Supported RX frame types:
    		 * IBSS: 0xd0
    		 * managed: 0x40 0xd0
    		 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
    		 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
    		 * mesh point: 0xb0 0xc0 0xd0
    		 * P2P-client: 0x40 0xd0
    		 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
    root@udoo-debian-hfp:~# iwconfig wlan0 mode master
    Error for wireless request "Set Mode" (8B06) :
        SET failed on device wlan0 ; Invalid argument.
    root@udoo-debian-hfp:~# ifconfig wlan0 down
    iwconfig wlan0 mode AP
    root@udoo-debian-hfp:~# iwconfig wlan0 mode AP
        invalid argument "AP".
    root@udoo-debian-hfp:~# ifconfig wlan0 up
    iwconfig wlan0 mode monitor
    root@udoo-debian-hfp:~# iwconfig wlan0 mode monitor
        SET failed on device wlan0 ; Device or resource busy.
  4. 2xyo
    2xyo New Member
    Nov 11, 2013
    I could not wait! So I recompiled the kernel with support for iptables (.config here)
    The Access Point works fine with this configuration.
    However, the bridge mode of hostapd doesn't work. I would indeed replace my old "Fonera plus" which works as follows:
    Eth0 : Internet (dynamic IP) <<= NAT + DHCPD + DNSMASQ =>> br0 (Eth1 + wlan0) 192.168.1.0/24
    Any advice is welcome !
  5. 2xyo
    2xyo New Member
    Nov 11, 2013
    I finally successfully set up a Wifi access point ( ethA > bridge [wifiB + usb ethC] ).
    Quick and dirty configurations files are available on https://gist.github.com/2xyo/8452047.
  6. jfey
    jfey New Member
    Nov 25, 2013
    I tried but can not build the driver - did you use the GUI Debian distri available via the UDOO site, the minimal system (unofficial) or did you build your own?
    If you have been using the release from the UDOO site, what have i to install first to build the driver?
    cheers
    Juergen
  7. 2xyo
    2xyo New Member
    Nov 11, 2013
    I use the official (old) Ubuntu image :
    # lsb_release -a
    No LSB modules are available.
    Distributor ID:	Ubuntu
    Description:	Ubuntu 11.10
    Release:	11.10
    Codename:	oneiric
    # uname -a
    Linux imx6-qsdl 3.0.35-2xyo-iptables-g76d54f2 #1 SMP Mon Jan 20 12:43:33 CET 2014 armv7l armv7l armv7l GNU/Linux
    You have to enable the support of iptables and recompile the Kernel Unico. Here is my .config.
  8. albertizzley
    albertizzley New Member
    Apr 15, 2014
    I'm interested in this functionality as well. @delba what is a current status on the tutorial you mentioned?
    Thanks
  9. delba
    1,064
    We're preparing a official UDOO OS (Ubuntu armhf) with hostapd already in it ;) Wait for it.
  10. jose
    jose New Member
    Jun 21, 2014
    Hi @delba, I'd really like to have this functionality. Do you have any news?
    Thank you
  11. delba
    1,064
