Debian SD Images - Dual and Quad
Discussion in 'Debian' started by mikelangeloz, Nov 5, 2013.
  1. matthias
    matthias New Member
    Oct 23, 2013
    That i know - still it wont help fix no hw acceleration.
    Also, image 1.3 is ubuntu, so it doesn't help with this image.
  2. madko
    madko New Member
    Nov 4, 2013
    I have the load fix and still no hardware acceleration. Any idea?
  3. matthias
    matthias New Member
    Oct 23, 2013
    same here (applied the load fix this morning).
    however, i did notice one thing:
    using the 1.3-ubuntu image, i get glxgear-FPS about 45FPS (showing "GL_RENDERER: GC2000 Graphics engine" - which should be HW-acceleration i guess)
    using the debian-image with load-fix, i get 47FPS (but showing "GL_RENDERER = Software Rasterizer" - should be no HW-acceleration only)
    so eighter debian is really this much faster - or it's only showing to use hw-acceleration, but isn't in reality...??
  4. madko
    madko New Member
    Nov 4, 2013
    What is your cpu usage in both case? FPS with glxgears is not really reliable but if you have less CPU usage in the Ubuntu, then it could be the HW acceleration.
  5. matthias
    matthias New Member
    Oct 23, 2013
    ubuntu:
    glxgears at about 40% (however, Xorg takes about 60% - so cpu is at 100% here).
    however, load average stays below 1 even if i run it for quite some minutes.
    debian:
    glxgears takes 99% (xorg sometimes 1-2%).
    load average seems to go up quickly...
  6. Shorack
    Shorack New Member
    Nov 3, 2013
  7. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Yep, just collecting some feedbacks in order to update the image with more fixes...
    Any idea on how to integrate hw video acceleration on debian armhf?
  8. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    Hi all,
    I'm trying to test the "minimal quad" image but the boot freezes at
    "Freeing init memory: 192K"
    The other image with LXDE works very well!
    Any ideas?
  9. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    There is an issue on the minimal . If you look it via serial this is what you'll get . Try to connect with SSH and you should have terminal access
  10. Shorack
    Shorack New Member
    Nov 3, 2013
    I'm afraid not. Not yet comfortable (at all) with the kernel and driver level things.
    That is why I'm so happy seeing you've put together a minimal debian. (ty!) ;)
  11. flok
    flok New Member
    Nov 19, 2013
    Many thanks for creating this image.
    Please please please consider migrating/extending the image so that it resides on an f2fs filesystem.
    f2fs greatly prolonges the life of an SD-card.
    On my raspberry pies for example I had to replace the sd-card once a month (+/-) and with f2fs they've been running for months already.
    F2FS kind of(!) lays an extra wearleveling layer onto the SD-card by not overwriting but storing data always in a new location. Only when the card has fully been filled, it starts to erase the "old data" flash segments and writing them with new data. So if you have 2GB of free space on the SD-card, that would mean you have 2GB of wearlevelling space.
    The newer version of F2Fs also stores data in the inode, reducing the disk space required.
  12. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Good to know Flok.
    Is there good support from Windows?Mac utilities that can cope with f2fs (as that is a consideration... the ability for people to write images to the SD cards on a host PC).
  13. madko
    madko New Member
    Nov 4, 2013
    Does Windows have support for ext3 right now?
    +1 for F2FS, don't care about windows support since only dd like tools should be enough
  14. jimmayhugh
    jimmayhugh New Member
    Nov 23, 2013
    NEVERMIND
    NEVERMIND... I removed and reinstalled sudo and the problem went away.
    When I try to run "sudo visudo", on the Quad Minimal Version I get the following error:
    using apt-get install shows that it's the latest version.
    any suggestions
  15. buggz
    buggz New Member
    Nov 25, 2013
    Hello,
    I am trying to use the non-GUI minimal image to install kali.
    I tried the maximal, too much stuffz already there, conflicts, etc.
    QUESTION: How do I get the minimal image, or ANY image to use the full size my card?
    I'm using a Sandisk 64gb card.
  16. buggz
    buggz New Member
    Nov 25, 2013
    Oh wow, too easy.
    gparted via systemrescuecd
    YEY!
  17. HixVAC
    HixVAC New Member
    Oct 25, 2013
    13
    So anyone have any issues getting stuck on first boot? I just loaded an SD with the quad minimal image and I'm constantly getting stuck at/around "Freeing init memory: 192K". Connected via serial and then I can't send and don't receive anything back, the terminal just freezes (no disconnect though).
    Any ideas?
  18. HixVAC
    HixVAC New Member
    Oct 25, 2013
    13
    Nevermind! Just saw the update from before stating that's a known issue.
  19. evilpengw1n
    evilpengw1n New Member
    Oct 21, 2013
    26
    Any plans to get this up to U-Boot 2013?
  20. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Yep! Gonna find some time to do that...
