Debian SD Images - Dual and Quad
Discussion in 'Debian' started by mikelangeloz, Nov 5, 2013.
  1. salouma
    salouma Member
    Jan 24, 2014
    49
    Thank you for that great OS,
    Is it possible to get the new Uboot version (this version is not working if you don't do a manual replacement of the Uimage)
    Is it normal not having a swap partition ?
    Best regards
  2. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
  3. ajfisher
    ajfisher New Member
    Sep 5, 2014
    HI all.
    Have got the quad image up and running on my board. I've noticed there is a known issue with the serial connection where it stops at a point during the boot sequence. As it happens, I need to get this to work as my Udoo is going to be the core of a robot so I need to be able to connect to it over serial from a PC occasionally in order to log into it an administer it (in the situation where wifi / network is unavailable or unreliable for some tasks).
    Is there a solution to this as I'd prefer to to use the minimal install as the max ubuntu one is terrible for my use.
    Cheers
    Andrew
  4. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Yep!
    Edit file
    /etc/inittab
    Change line
    T0:23:respawn:/sbin/getty -L ttyS0 115200 vt100
    to
    #T0:23:respawn:/sbin/getty -L ttyS0 115200 vt100
    T0:23:respawn:/sbin/getty -L ttymxc1 115200 vt100
    Let me know!
  5. ajfisher
    ajfisher New Member
    Sep 5, 2014
    Thanks for that - in the end I actually found a bunch of other things I needed to do as well so I've rolled my own version of minimal Ubuntu 14.04 which works quite nicely!
  6. Morlock
    Morlock New Member
    Nov 1, 2013
  7. araknus
    araknus New Member
    Nov 20, 2014
    Hey, I just installed minimal debian on my udoo and when I'm trying to connect through serial port all i have is black window. No data in or out. Is serial ssh already on in this distro?
  8. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    To enable serial debug you just need to edit
    /etc/inittab
    Change line
    into
    Save file and reboot. Voilà!
