Detect USB network not connected
Discussion in 'UDOO NEO' started by Maurice, Dec 14, 2016.
  1. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    I'm trying to start my program when I'm not connected to my PC, so my program automatically starts when I run the Neo connected to a USB battery pack, but not when to my development PC. I thought that I could do that by checking if the 7.2 address is configured.
    I have added to /var/rc.local the following code:
    usb_inet=$(ifconfig | grep -c 192.168.7.2)
    if [ $usb_inet -eq 0];
    then
    fi
    Unfortunately it seems that when connected to a battery pack the USB network looks like it is up to, the grep still returns 1.
    So if it is not the 7.2 ip address, what else could be checked to see how the board was booted.
    Perhaps ping your development PC from the Neo, but that will only work if you are not connected to wifi or Ethernet to your network.
  3. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Note that usb0 is always up due to settings in /etc/network/interfaces.
    The line
    inet addr:192.168.7.2  Bcast:192.168.7.255  Mask:255.255.255.0
    is always in ifconfig.
  4. Maurice
    Oct 13, 2015
    394
    87
    @Gorgo, thanks. I assumed something like this, or at least, I thought that as long as power was detected on the USB port the interface would be up. And as I'm using a powerbank that would be the case in my project.
    I now use a semi-automatic solution: I check if a certain file exists, and if it does I autostart my program.
  5. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Check this: if you plug your battery, is usb0 running or not?
    If not, you can use
    ifconfig usb0| grep -c RUNNING
  6. Maurice
    Oct 13, 2015
    394
    87
    If the Neo is powered from the barrel jack USB0 is not running, if it powered from the battery it is :(. Thanks for the suggestion.
