digitalWrite hangs sketch
Discussion in 'UDOO NEO' started by Maurice, Apr 19, 2016.
  1. waltervl
    Maurice, as in the other issue was written it is not allowed by NXP to set the pinmode in the main loop. Only during the setup section. I think this is the root cause of the problem you are facing with digitalwrite. For analogwrite you are also not allowed (or it is now neglected) to do a pinmode at all.
  2. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    @waltervl, if you don't do a digitalWrite() then the display works fine, with the code that switches pinMode() for the display, if this would not be allowed by NXP the display would never ever work, and that is not the case. The digitalWrite I do has no relation with the pins used by the display. Here is a code illustrating the problem: http://pastebin.com/VPLWQ82d
    As I now also own a Arduino Mega 2560 I have verified that it does work on an Arduino. UDOO claims the Neo is Arduino compatible. If what you are saying is correct the Neo is not, and will never be, Arduino compatible, but my display would never work, and yet is does as long as you don't do a digitalWrite().
    edit: The skillfull technicians of UDOO are checking this out, I think it is better to have them give the answer
  3. Andrea Rovai
    Dear Maurice,
    I'm sorry if this takes some time, we'll answer you in the ticketing system.
  4. Maurice
    Oct 13, 2015
    394
    87
    That is no problem. I know that it is on your list. I can continue at this time with my Arduino Mega.
