Direct USB connection Ubuntu 15.10 [SOLVED]
Discussion in 'UDOO NEO' started by Lorenzo Benvento, Feb 10, 2016.
  1. Lorenzo Benvento
    Lorenzo Benvento New Member
    Feb 10, 2016
    Let me know if it's possible to use Direct USB Connection from Ubuntu. I have not found documentation about.
    Thanks.
    Andrea Rovai likes this.
  3. Lorenzo Benvento
    Feb 10, 2016
    I'm sorry for my bad English. Yes, I want to connect from a Ubuntu 15.10 PC to the Neo.
    Thanks.
  4. waltervl
    I am also sorry, I can't help you as I don't have a Linux pc. But did you try it? Did the Neo show up a a device? Could you connect to it on IP 192.168.7.2 ?
  5. rreignier
    rreignier New Member
    Nov 7, 2015
    Hi Lorenzo,
    For sure, you should be able to use a Direct USB connection between your Neo and a Linux computer. The drivers are already built-in the Linux Kernel.
    You should have a new network interface `usb0`, a serial interface in `/dev/ttyACM0` and a USB Mass storage mounted.
  6. Francesco
    Francesco Active Member
    Jun 23, 2015
    220
    110
    On Ubuntu 15.10 and 16.04 (still alpha) usb0 is not automatically connected for some reason.
    I use this workaround:
    sudo ifconfig `ifconfig |grep enx |awk '{print $1}'` 192.168.7.1
    Krista Hill and Andrea Rovai like this.
  7. Lorenzo Benvento
    Feb 10, 2016
    It worked! Thanks a lot!
  8. Krista Hill
    Krista Hill New Member
    May 26, 2017
    20
    Thank you for your post. I used ifconfig to identify the RNDIS network adapter name, then made a change to what you posted. This is another step in the right direction
