Double to String conversion
Discussion in 'UDOO NEO' started by William Warke, Dec 20, 2016.
  1. William Warke
    William Warke New Member
    Oct 5, 2016
    Has anyone figured out how to reliably convert doubles to strings (String or char*) on the Neo? Mine locks up when I try to run the following code:
    double x = 1234.56;
    String s = String(x, 2);
    snprintf doesn't like "%f"s either, so I'm at a loss here.
  2. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    I also saw this problem on neo, see here
    The solution that i use for the moment is to send only int from M4 to A9 and convert it in float A9 side with c++ ...
  3. William Warke
    Oct 5, 2016
    Thanks, I didn't find that thread when I searched for the problem. I'm actually trying to write values to a file, not send them over serial, otherwise I would try your solution. I'll move on over to your thread now...
    modjo likes this.
