I need to configure pin 27 of CN25 (KSO10) as an ouput GPIO by using EAPI_Test program. IIUC, I need to run something like this: sudo ./EAPI_Test -gs 0 <param_2> <param_3> 0 It is not clear, however, what values I have to use for <param_2> and <param_3>: <param_2> -> ID (see 9.1.1 in COM_EAPI_R1_0.pdf <param_3> -> Bitmask (see 9.1 in COM_EAPI_R1_0.pdf Any help would be appreciated. Thank you.
I did some tests and found the following correlation between PIN # / FUNCTION / EAPI ID: PIN >>> EAPI ID 13 >>> 0 14 >>> 5 15 >>> 1 16 >>> 6 17 >>> 2 18 >>> 7 19 >>> 3 20 >>> 8 21 >>> 4 22 >>> 9 23 >>> 10 24 >>> 13 25 >>> 11 26 >>> 14 27 >>> 12 28 >>> 15 so, in your case, to set the PIN 27 to output it should be: Code: EAPI_Test -gs 0 12 1 0 (I always use 1 for the bitmask) and then you change the value with: Code: EAPI_Test -gf 0 12 1 0 EAPI_Test -gf 0 12 1 1
I think it might me good for this relations between CN25 pin and EAPI ID to be on the Documentation in https://www.udoo.org/docs-bolt/Hardware_References/Pinout_Headers.html
Hi, I have a problem using GPIO via the EAPI_Test program. I am following the description by Maximo. The command sudo ./EAPI_Test -gp 0 0 seems to work since it produces output. Running the command "sudo ./EAPI_Test -gs 0 0 1 1" I get "EAPI_STATUS_TIMEOUT". The reason to use sudo is to avoid permission violation. My UDOO Bolt V8 runs Ubuntu 22.04. Is it possible that I have to change something in BIOS to get it work?? Where can I find source code for the EAPI to be able to debug this software?
