Ef1 Boot Devices
Discussion in 'UDOO X86' started by ottyphc, Apr 26, 2017.
  1. ottyphc
    ottyphc New Member
    Jun 27, 2013
    27
    I have successfully installed windows 10 and it has been functioning very well. After the install the Boot menu no longer lists devices under EF1 Boot Devices. This is a problem because I still want to install Linux.
    Does anyone know how I can get these devices to appear again under EF1 Boot Devices.
    Don
  2. bpr
    bpr New Member
    Nov 11, 2013
    10
    google seems to suggest that, on laptops anyway, the solution is to power down and remove the disk devices, then reattach it (them) carefully and finally repower and check the bios again... apparently it's often due to a poor connection problem
  3. ottyphc
    ottyphc New Member
    Jun 27, 2013
    27
    Tried the device disconnect. Still no devices listed under EF1 Boot Devices.
  4. ottyphc
    ottyphc New Member
    Jun 27, 2013
    27
    I would like to get back to the Boot menu that listed the devices. I don't know what I did to loose them. I just followed the udoo x86 instructions. Anyone else have this problem?
  5. Alexander Chang
    Alexander Chang New Member
    Apr 27, 2017
    I have the same issue here. What's worse is I didn't complete win 10 installation! It's just gone. Now I can't even boot from a bootable USB.
    Any suggestion?
    從我的iPhone使用Tapatalk 發送
  6. Alexander Chang
    Apr 27, 2017
    It just appeared from nowhere. I did unplug the win10 USB and plug it in again but not to the end. I'll test it after win 10 installation to see if there is still an issue.
  7. Andrea Rovai
    Maybe you see the devices listed in Legacy, do you?
    Can you send us a photo?
    What devices you see listed?
  8. ottyphc
    ottyphc New Member
    Jun 27, 2013
    27
    Below is what is written on the Boot Manager screen:
    Boot Manager
    LEGACY Hard Drive
    DF4032
    SanDisk SDSSDA480G
    TS128GMTS600
    EF1 Boot Devices
    Internal EF1 Shell
  9. ottyphc
    ottyphc New Member
    Jun 27, 2013
    27
    I understand that pressing f9 in the bios will set the bios back to factory defaults.
    My question is:
    Will resetting to default bring the bios back to the same state as it was received from UDOO or will it set it to something else?
    I am hoping this reset will allow me to see and select the ef1 boot devices again.
  10. ottyphc
    ottyphc New Member
    Jun 27, 2013
    27
    I hope someone can answer this question for me.
    After installing an OS on udoo can you still see the efi boot devices in the boot manage or do you only see legacy devices?
    I had installed windows 10 successfuly on the 128gb m2 ssd. However when I installed Ubuntu 16.04 on the 32gb emmc udòox86 would only boot ubuntu. I could no longer boot Windows from the legacy 128 sdd. It would boot ubuntu instead. I tried to reinstall windows 10 on the 128gb ssd, but the windows install says it can't find or create a partion on that drive. I formated a single ntfs partion on the ssd with 119gb available. Windows still can't proceed with the installation. From ubuntu, it has no problem work with this ssd. I can't understand why windows is having problems with the install. Any ideas??
