Error: "Undefined error to"
Discussion in 'Arduino IDE' started by wertiti, May 5, 2017.
  1. wertiti
    wertiti New Member
    Mar 28, 2017
    I try to create Arduino library for UDOO but I've an issue during compilation. Indeed, I suceed to compile my program by selecting classic Arduino board like "Arduino MEGA" but when I select "UDOO Neo (Cortex M4)" in Arduino IDE, I've the following error :
    C:\Users\Ivan\AppData\Local\Temp\arduino_build_724166\sketch\UDOO_test.ino.cpp.o: In function `setup':
    C:\Users\Ivan\Documents\Arduino\UDOO_test/UDOO_test.ino:9: undefined reference to `OICom'
    collect2.exe: error: ld returned 1 exit status
    exit status 1
    Erreur de compilation pour la carte UDOO Neo (Cortex M4)
    I did some testing with very simple program splited into 3 files and I've the same error:
    .Ino file :
    #include <OICom.h>
    void setup() {
    OIcomLib.test();
    OICom.begin();
    void loop() {
    .cpp file
    #include "OICom.h"
    void OIComLib::test()
    .h file
    // OICom.h
    #ifndef _OICOM_h
    #define _OICOM_h
    #if defined(ARDUINO) && ARDUINO >= 100
        #include "arduino.h"
    #else
        #include "WProgram.h"
    #endif
    class OIComLib
    public:
        void test();
    extern OIComLib OICom;
    #endif
    When I write this program in one file (in .ino file), I suceed to compile.
    Thank for your help
