hi, i am using udoo neo for my project with android 6.0, so i have building android aosp for udoo neo, when i build the android aosp i got following error i don't know how to solve this error, please could you tell me how to fix this error, i am using ubuntu 14.04 with 64 bit system LD [M] backports/drivers/net/wireless/ti/wl18xx/wl18xx.o fatal: Not a git repository (or any of the parent directories): .git CHK backports/drivers/net/wireless/ti/wlcore/version.h UPD backports/drivers/net/wireless/ti/wlcore/version.h CC [M] backports/drivers/net/wireless/ti/wlcore/main.o arm-eabi-gcc: error: backports/drivers/net/wireless/ti/wlcore/main.c: No such file or directory arm-eabi-gcc: fatal error: no input files compilation terminated. make[6]: *** [backports/drivers/net/wireless/ti/wlcore/main.o] Error 1 make[5]: *** [backports/drivers/net/wireless/ti/wlcore] Error 2 make[4]: *** [backports/drivers/net/wireless/ti] Error 2 make[3]: *** [backports/drivers/net/wireless] Error 2 make[2]: *** [backports] Error 2 make[1]: *** [sub-make] Error 2 make: *** [kernelmodules] Error 2 #### make failed to build some targets (08:58 (mm:ss)) #### thank you,
Can I get your build machine sent to me then, please? I notice some trickery with git in the makefile for wlcore. There is also some "if you do not have a git repo" attempt at a solution in there, but it does not help removing the .git folder from kernel_imx. This only changes the error slightly. It is quite frustrating that this does not work out of the box using the guidelines. Could it be related to some git setup needed for the version control in the makefile?
If I remember correctly I have got the same error when preparing Android 7. Have a look on the last commits of kernel_imx/ and build/, I cannot recall how I have fixed it... You can also try to install Ubunu 16.04 on a VM. It is hard for me to send you our physical server
Has anyone been able to work it out? I've been encountering the same error while building android aosp. Ronny Sharma showbox.onl mobdro.one dltutuapp.com
