I have an external USB drive that I had working perfectly fine with my raspberry pi, and now I want to use it with my udoo. I setup an SD card with ubuntu 12.04 on my udoo quad, and now I'm trying to mount the NTFS partitioned drive. I have the following issue: Code: arjun@udoo:~$ sudo fdisk -l Disk /dev/mmcblk0: 7948 MB, 7948206080 bytes 255 heads, 63 sectors/track, 966 cylinders, total 15523840 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x000c356e Device Boot Start End Blocks Id System /dev/mmcblk0p1 16065 14201459 7092697+ 83 Linux Note: sector size is 4096 (not 512) Disk /dev/sda: 3000.6 GB, 3000558944256 bytes 255 heads, 63 sectors/track, 45599 cylinders, total 732558336 sectors Units = sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk identifier: 0x000246c6 Device Boot Start End Blocks Id System /dev/sda1 256 653442047 2613767168 7 HPFS/NTFS/exFAT /dev/sda2 653442048 732558335 316465152 7 HPFS/NTFS/exFAT arjun@udoo:~$ sudo mount -t ntfs-3g /dev/sda1 /media/mybook FATAL: Module fuse not found. fuse: device not found, try 'modprobe fuse' first arjun@udoo:~$ sudo modprobe fuse FATAL: Module fuse not found. arjun@udoo:~$ sudo apt-get install fuse Reading package lists... Done Building dependency tree Reading state information... Done fuse is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 23 not upgraded. arjun@udoo:~$ what exactly is fuse and why isn't it working? when I do Code: sudo apt-get install fuse it insists that It is "already the newest version" while Code: sudo modprobe fuse says that it can't find the module "fuse". What's going on here?
I also tried this: http://ubuntuforums.org/showthread.php?t=148359 and "fuse" never shows up in the module assistant.
FUSE needs to be in the Kernel and it is not... When I have time I'll compile the Kernel with all the necessary modules included in. If someone beats me to it I'll be happy to use it
Thanks! I had the same issue w/ Ubuntu 11 and 12. Ended up using Wheezy and that worked for me. I'd be happy to switch back to Ubuntu though!
