fade example not working in M4
Discussion in 'UDOO NEO' started by Matt557, Apr 2, 2016.
  1. Matt557
    Matt557 New Member
    Nov 24, 2015
    Hello Udooers,
    I tried running the fade example from the Arduino IDE, but it is not working. The blink example works fine, also from the web interface (192.168.7.2) if I click Arduino/Fade/run, it works, but not if I upload the the code from Arduino IDE.
    I observed, that indeed the during the FIRST iteration of the loop function the brightness value is correctly set by the analogWrite function, but all other iterations cause the LED to turn off instead of changing the light intensity. For example I set brightness to 255 and delay(1000), the LED shines 1 second and then turns out. If I leave brightness at 0, it won't shine at all.
    The M4 without working PWM is not very usefull at all...
    Thanks for suggestions!
  3. Matt557
    Matt557 New Member
    Nov 24, 2015
    Hi Walter,
    thx for the information. I tried it and just uncommented the line pinMode(9, OUTPUT) in the fade sketch.
    Unfortunately the result is the same....still no fading diode.
    Are there any other known issues with the PWM?
    Thanks,
    Matt
  4. waltervl
    Can you try it again with the just released udoobuntu 2 rc2?
  5. waltervl
    Well, you don't have to test. It does not work :(
    The servo sweep example is working though so it seems that the analogwrite does not compile correctly.
    The examples on the web-conf seems to be precompiled binaries that are pushed to the M4
  6. Matt557
    Matt557 New Member
    Nov 24, 2015
    thx for your help! I did update via apg-get, so I should have the newest release.
    So it seems like PWM on M4 doesn't work at all with the current libraries? Not being able to use the analogWrite command looks like a serious issue to me....
  7. waltervl
    I already made an issue on github repository. I saw they made a lot of changes on the Arduino environment so 1 of them messed up the PWM I guess. Technically it is working (see the precompiled web example) only the current compiler does something wrong.
  8. Matt557
    Matt557 New Member
    Nov 24, 2015
    that's really nice. Thank's for your help!
  9. ektor5
    Jul 1, 2013
    97
    48
  10. Matt557
    Matt557 New Member
    Nov 24, 2015
    works fine, very nice! :)
  11. waltervl
    Did you still have to out comment the pinmode of the PWM pin?
  12. ektor5
    Jul 1, 2013
    97
    48
    Yes, I'd be better.
    MQX don't support INPUT/OUTPUT definition of PWM pins.
    ek5
