Fixing sound sample rate issues - crackling audio etc
Discussion in 'Linux Ubuntu' started by lindsayhorner, Mar 30, 2014.
  1. lindsayhorner
    lindsayhorner New Member
    Mar 26, 2014
    Hi
    I've just been setting up Shairplay - https://github.com/abrasive/shairport - so my Udoo can function as a an Airplay receiver. It's all working really well and the only issue I've had to work around was an annoying crackle/pop/distortion which was occurring whilst playing back songs from my phone.
    The solution was easy, and it related to the sample rate of the mp3's I was playing (44Khz vs 48Khz). Note that this is whilst using the Udoo's internal sound card and speaker out, with ALSA handling the playback. You'll need to add a config file:
    sudo nano ~/.asoundrc
    And then add this to it:
    pcm.!default
      type plug
      slave sl1
    ctl.!default
      type hw
      card 0
    pcm_slave.sl1
      pcm "hw:0,0"
      format S16_LE
      channels 2
      rate 44100
    Hope this helps someone!
