I have my bios boot sequence set to boot to the NVMe Windows boot loader as the first option but it just ends up hanging. When I go down to override boot sequence, and select Windows boot loader, it starts up perfectly fine. This is a bit of problem because I want to run the Gear headless but if it can't reboot, this is useless. Anyone else having this issue?
Please look for this thread and specifically my last post https://www.udoo.org/forum/threads/...l-hardware-bios-reset.30446/page-2#post-60486 as this may be relevant to your problem, IF the hangs is in b4/a0 state (lower right corner of screen).
Do you have other OS's like Linux installed or just only Windows? Did you change other related Bios options? Did you try to reset Bios to factory settings?
Yes, I did all that. I gave up with it and swapped it out with a non NVME drive and it works fine. So there is something borked with the BIOS for NVME Windows boot drives.
