Hi, I have to monitor signals on many gpios but via proc fs it takes a lot of CPU. There is a faster way but I need some help. http://www.black-swift.com/wiki/index.php?title=Working_with_GPIOs_(C/C++) We could have access to gpios directly via memory blocks but I dont know base address for gpios and mem block size. I have investigated topic and probably base addr is at 0x20000000 but I dont know mem block size ( probably 16K). Could you confirm the informations? best regards,
Hi, I resolved a problem. Please check link https://community.freescale.com/thread/381277. Use example with mmap from userland and test on pin 40th. My previous thinking has been wrong. Code: example for pin 161 with no changed comments #include <stdio.h> #include <stdlib.h> #include <errno.h> #include <fcntl.h> #include <sys/mman.h> #include <errno.h> #include <string.h> #include <stdint.h> #include <unistd.h> #define IOMUXC 0x020E0000 #define IOMUXC_SW_MUX_CTL_PAD_SD4_DATA0 0x020E031C #define GPIO2_DR 0x020B0000 //#define GPIO2_GDIR 0x020A0004 #define GPIO2_GDIR (GPIO2_DR + 0x04) #define GPIO2_PSR 1 static volatile uint32_t *gpio; int main(int argc, char **argv) { int fd ; //Obtain handle to physical memory if ((fd = open ("/dev/mem", O_RDWR | O_SYNC) ) < 0) { printf("Unable to open /dev/mem: %s\n", strerror(errno)); return -1; } /** * Map some of the pin mux registers within the range of the * GPIO40 GPIO40 pin. **/ gpio = (uint32_t *)mmap(0, (getpagesize() * 250), PROT_READ|PROT_WRITE, MAP_SHARED, fd, IOMUXC); // The first 3 bits are the only thing that matters here according to the // datasheet. *(gpio + ((IOMUXC_SW_MUX_CTL_PAD_SD4_DATA0 - IOMUXC) / 4)) = 0x5; //Be a good neighbor if((munmap((void *)gpio, (getpagesize() * 250))) < 0){ printf("munmap failed: %s\n", strerror(errno)); exit(1); } /** The i.MX 6 Dual and Quad Processor have 7 GPIO banks * Each bank amounts to 1mb of memory which is perfectly * aligned for a memory map. Mmap will fail if the offset * is not a multiple of 1mb. For this example I just want * the GPIO2 bank which starts at 0x020A0000. I want the * bank (1mb or 250 pages of memory). I could get away with * a single page, but I am greedy :-P. **/ gpio = (uint32_t *)mmap(0, (getpagesize() * 250), PROT_READ|PROT_WRITE, MAP_SHARED, fd, GPIO2_DR); if ((int32_t)gpio < 0){ printf("mmap failed: %s\n", strerror(errno)); exit(1); } /** * Setup GPIO40 or GPIO2_IO08 as an output. * gpio[1] is the GPIO direction register (GPIO2_GDIR). * We want to only want to set bit 8 of this register * to a binary 1 while leaving the rest intact. **/ *(gpio + ((GPIO2_GDIR - GPIO2_DR) / 4)) = *(gpio + ((GPIO2_GDIR - GPIO2_DR) / 4)) | 1<<GPIO2_PSR; /** * Blink GPIO40 every 500 milliseconds. * gpio[0] is the GPIO data register (GPIO2_DR). * We only want to toggle bit 8 of this register * while leaving the rest alone. **/ while(1){ *(gpio + ((GPIO2_DR - GPIO2_DR) / 4)) = *(gpio + ((GPIO2_DR - GPIO2_DR) / 4)) ^ 1<<GPIO2_PSR; usleep(250000); *(gpio + ((GPIO2_DR - GPIO2_DR) / 4)) = *(gpio + ((GPIO2_DR - GPIO2_DR) / 4)) ^ 1<<GPIO2_PSR; usleep(250000); } }
