I managed to set a udoo neo as a bridge. - I bought a Wifi dongle (https://www.amazon.it/DONGLE-FERGUS...ie=UTF8&qid=1498469964&sr=8-1&keywords=rt5370). It's a Ralink rt5370 antenna. - I installed firmware-ralink package, wpasupplicant and wireless-tools - Edit /etc/network/interfaces and add wlan0 and wlan1 Code: # Loopback network interface auto lo iface lo inet loopback # Primary network interface #auto eth0 #iface eth0 inet dhcp # USB OTG connection allow-hotplug usb0 iface usb0 inet static address 192.168.7.2 netmask 255.255.255.0 auto wlan0 iface wlan0 inet dhcp wpa-conf /etc/wpa_supplicant.conf # WiFi auto wlan1 iface wlan1 inet static address 192.168.22.1 netmask 255.255.255.0 #hostapd /etc/hostapd/hostapd.conf - Edit /etc/default/hostapd Code: # Defaults for hostapd initscript # # See /usr/share/doc/hostapd/README.Debian for information about alternative # methods of managing hostapd. # # Uncomment and set DAEMON_CONF to the absolute path of a hostapd configuration # file and hostapd will be started during system boot. An example configuration # file can be found at /usr/share/doc/hostapd/examples/hostapd.conf.gz # DAEMON_CONF="/etc/hostapd/hostapd.conf" # Additional daemon options to be appended to hostapd command:- # -d show more debug messages (-dd for even more) # -K include key data in debug messages # -t include timestamps in some debug messages # # Note that -B (daemon mode) and -P (pidfile) options are automatically # configured by the init.d script and must not be added to DAEMON_OPTS. # #DAEMON_OPTS="" - Edit /etc/hostapd/hostapd.conf Code: hw_mode=g channel=11 driver=nl80211 ssid=my-network-name interface=wlan1 # possible MAC address restriction #macaddr_acl=0 #accept_mac_file=/etc/hostapd.accept #deny_mac_file=/etc/hostapd.deny #ieee8021x=1 # Use 802.1X authentication # encryption wpa=2 wpa_passphrase=my-secret-password wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP CCMP rsn_pairwise=CCMP ctrl_interface=/var/run/hostapd # Only root can configure hostapd ctrl_interface_group=0 - Install dnsmasq ( apt-get install dnsmasq ) - Edit /etc/dnsmasq.conf and add: Code: interface=wlan1 dhcp-range=192.168.22.2,192.168.22.100,2h - Edit /etc/rc.local and add: (This step may not be necessary) Code: rfkill unblock wlan0 && hostapd /etc/hostapd/hostapd.conf - Remove network-manager (apt-get remove network-manager) - Edit /etc/default/isc-dhcp-server Code: # Defaults for isc-dhcp-server initscript # sourced by /etc/init.d/isc-dhcp-server # installed at /etc/default/isc-dhcp-server by the maintainer scripts # # This is a POSIX shell fragment # # Path to dhcpd's config file (default: /etc/dhcp/dhcpd.conf). #DHCPD_CONF=/etc/dhcp/dhcpd.conf # Path to dhcpd's PID file (default: /var/run/dhcpd.pid). #DHCPD_PID=/var/run/dhcpd.pid # Additional options to start dhcpd with. # Don't use options -cf or -pf here; use DHCPD_CONF/ DHCPD_PID instead #OPTIONS="" # On what interfaces should the DHCP server (dhcpd) serve DHCP requests? # Separate multiple interfaces with spaces, e.g. "eth0 eth1". INTERFACES="usb0" - Edit /etc/dhcp/dhcpd.conf Code: default-lease-time 86400; max-lease-time 8640000; log-facility local7; subnet 192.168.7.0 netmask 255.255.255.0 { option routers 192.168.7.2; option subnet-mask 255.255.255.0; range 192.168.7.1 192.168.7.100; } #subnet 192.168.100.0 netmask 255.255.255.0 { # option routers 192.168.100.1; # option subnet-mask 255.255.255.0; # range 192.168.100.10 192.168.100.20; #} - Enable ip_forwarding with echo Code: echo 1 > /proc/sys/net/ipv4/ip_forward or to make it permanent, edit /etc/sysctl.conf Code: net.ipv4.ip_forward=1
