I was looking in the bios to try to set the primary video adapter as im using both dp and hdmi and i hapen tp disable it video card. how do i reset the bios? or can someone give me the key combos to reset the bios? ive tryed todo the boot disk bios update but it doesn't seem to be doing anything. my fan is running constantly so i think something else is happening, i tired pulling the battery in an effort to reset the bios, im asuming that may have caused a error
If you are lucky you have set up your system that it will boot from USB if connected. Then you can create a bootable USB with DOS (use Rufus) according the update uefi instructions. If you create an autoexec.bat with the update command on that USB disk it will update and reset your Udoo automatically.
See the thread https://www.udoo.org/forum/threads/doesnt-start-flashing-green-amber.7044/, especially:
