How have you solved on off? Just solder a
Discussion in 'UDOO X86' started by Triodefreak, May 7, 2017.
  1. Triodefreak
    Triodefreak Active Member
    Jun 7, 2016
    104
    30
    On off switch to pin 6 and 8?
  2. Kilrah
    Kilrah Member
    Apr 20, 2017
    31
    16
    Press the existing power button?
  3. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    92
    Pressing that does nothing.
  4. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    It works OK for me! If the UDOO is powered on with LED green then it is powered off and the LED changes to Amber to indicate power present but UDOO powered off. Pressing it again causes the LED to turn green and the UDOO starts booting. The button is very small, though, so can be a bit fiddly to press.
    fabio978 likes this.
  5. Laurence
    Laurence New Member
    May 8, 2017
  6. x1800MODMY360x
    x1800MODMY360x Member
    Mar 29, 2017
    55
    yes pin 6 is the open and pin 8 is the ground for pin 6 on the header.
  7. Triodefreak
    Jun 7, 2016
    104
    30
    Could not find that in the user manuals?
  8. Kilrah
    Kilrah Member
    Apr 20, 2017
    31
    16
    On the board edge right next to the LED.
  9. Triodefreak
    Jun 7, 2016
    104
    30
    Bummer. I'll have to start soldering then. Since with the supplied enclosure I'll have to get a little rod to push that button.
  10. Triodefreak
    Jun 7, 2016
    104
    30
    Pity they don't sell connectors for the speakers...and optional frontpanet switches indicators et al...in their own shop. I'm having problems finding the parts...elsewhere.
  11. Kilrah
    Kilrah Member
    Apr 20, 2017
    31
    16
    I don't need anything to press the power button with the acrylic case. The one on the EDGE, not the top one below the hole.
    Triodefreak likes this.
  12. Triodefreak
    Jun 7, 2016
    104
    30
    Cool! Thanks. Will check it tonight.
  13. LDighera
    LDighera UDOOer
    Jan 13, 2014
    206
    36
    If you press the button on the edge below the LED while it is green and fail to see any response, it can indicate that the X86 board is being back-fed through the USB port to which you've attached a separately powered USB hub. To test, disconnect the USB hub, and press On/Off button; the LED should turn amber.
  14. Markus Laire
    Mar 9, 2017
    225
    92
    I retested power button again and now it is working in Debian Stretch. It didn't work last time I tried, but I don't remember what the exact situation was then.
    Still I prefer to have also additional button on a cable (adafru.it/1125) like what @Laurence showed above so I can cut all power to UDOO X86.
  15. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    Why soldering? Can't you use a Dupont connector/header? I have added a power button with led (used for HDD activity or Power) like that.
    drc85 likes this.
  16. Triodefreak
    Jun 7, 2016
    104
    30
    Thank you for that name. Never knew what they were called. I know I have them somewhere in my hobby room.
  17. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    I recycled them for years from old computers, until i decided to search for their actual name ;)
  18. thE_29
    thE_29 Member
    May 2, 2017
    34
    In that video:
    you can see, that the guy added an "external button". Someone knows where to get something like that?
    Link:
    youtube.com/watch?feature=youtu.be&v=nQQbSBCfm_4
  19. x1800MODMY360x
    Mar 29, 2017
    55
    I found the external button but this forum does not like my phone and won't let me paste the link to it. I've search external front panel pc button and got it that way.
  20. thE_29
    thE_29 Member
    May 2, 2017
    34
